Alarm/immobilizer blinking light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tony Rico, May 16, 2021.
  1. Tony Rico
    Tony Rico Junior Member
    Does the dash light (car with a key) blink all the time the vehicle is off weather or not the doors are locked/
    49,446
    yes, that's why your 12v goes dead
  3. dolj
    dolj Senior Member
    7,648
    3,859
    Wellington, New Zealand
    If that's all it takes to flatten the 12 V battery, it needs replacing.
    It shouldn't flash unless the car is locked and the imobbilzer is enabled (which is what that flashing symbol means). The only (normal) way to lock the car without enabling the imobilizer is to manually lock it with the mechanical key.
