Alarm keeps going off at random times
Discussion in 'Gen 3 Prius Technical Discussion' started by Zradub, Sep 9, 2020.
  1. Zradub
    Zradub Junior Member
    40
    Hi All. My 3rd Gen Prius’s alarm has started to go off randomly. Just this morning it went off unprovoked, just as I was going to grab the key fob from the key rack it turned itself off. I was told it went off yesterday as well when I wasn’t around so I unlocked the car so I could start researching this. Then it went off again. A quick search hasn’t found anything yet. It’s a 2010 top level ‘V‘ with both the Navigation and Advanced Technology packages in case this makes any difference to figuring this out. In the meantime is there a fuse or something I can pull to disable the alarm?
    Thank you for you help.
  2. Fuegoman
    Fuegoman Junior Member
    Following
    I have the same problem.
  3. Zradub
    40
    Bump. It still does this maybe twice a month. Did it yesterday 3x in 15-20min with nothing disturbing the car. Pls help.
  4. Kenny94945
    Kenny94945 Active Member
    857
    433
    Sausalito
    2016 Prius v wagon
    FWIW
    What causes an alarm to activate?
    The easiest answer may be an open door.
    Perhaps the sensors in the door jams (or lift gate jam) are dirty or mis-aligned.
    Lastly, maybe not Prius specific, Merc Benz alarms have batteries in them; maybe the Prius does too and replacement is needed?
    Good luck.
  5. Zradub
    40
    Thanks. I’ll clean the sensors.
    Is there a way to disable the audible alarm?
