Alarm keeps randomly going off. Help
Discussion in 'Gen 3 Prius Main Forum' started by Zradub, Oct 5, 2020.
Tags:
  1. Zradub
    Zradub Junior Member
    40
    Hi All. My 3rd Gen Prius’s alarm has started to go off randomly. Just this morning it went off unprovoked, just as I was going to grab the key fob from the key rack it turned itself off. I was told it went off yesterday as well when I wasn’t around so I unlocked the car so I could start researching this. Then it went off again. A quick search hasn’t found anything yet. It’s a 2010 top level ‘V‘ with both the Navigation and Advanced Technology packages in case this makes any difference to figuring this out. In the meantime is there a fuse or something I can pull to disable the alarm?
    Thank you for you help.
    Reposted from Tech forum for lack of help.
    52,580
    do you have a second fob?
  3. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Repost this in the accessories section, and you cover half of the turd gen forum.
  4. Zradub
    40
    No, unfortunately just one.
  5. bisco
    52,580
    Might be the problem, hard to say
  6. Zradub
    40
    2 years later and it still does it. Anyone have any ideas? Btw how much is a 2nd Fob?
  7. alexk345
    alexk345 Junior Member
    46
    india
    I have same problem. it started small issue now its 100% alarm when i connect battery
  8. BiomedO1
    BiomedO1 Senior Member
    4,374
    2,302
    Left Coast
    You need to figure out which sensor is setting off the alarm - most likely the driver's door switch. Since that's the one used most often.
  9. Carall
    Carall Active Member
    316
    104
    Harrisonburg, VA
    There is no button rubber insert in your key shell i guess, and the circuit board has oxidized. I recently fixed the same issue. You can download the magnifier app on your phone and use a needle or a sharp pick tool to scrape all the oxidation off the board. After I did that, the problem was solved. When you look at the board you most likely won't see the oxidation until you use the magnifier app.
  10. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    It’s impossible to steal a turd gen without the fob, just rip the alarm out and drink a cold one after.
  11. BiomedO1
    4,374
    2,302
    Left Coast
    So your saying it's the FOB panic button setting off the alarm. That should be easy to check. Either place the FOB in a Fairaday bag or pull the battery out of the FOB or move the FOB into your refrigerator - then reconnect the battery. It shouldn't alarm, since you've removed the signal source, setting off the alarm.
    In case you haven't figured it out, placing your FOB in the refrigerator blocks the signals being transmitted.
  12. alexk345
    46
    india
    Guys Guys ,
    It looks solved.
    Tell everyone has this problem
    Ask them if they park in street. If they say it then its just this problem
    I was removing every fuse to see if alarm can be stopped.
    Then land lord came , he is truck driver.
    he went under front of car and did something and fixed the alarm
    He is not telling me the secret. if anyone know what he did , i am interested
    I drove 12 miles and no alarm today.
  13. ASRDogman
    ASRDogman Senior Member
    7,920
    4,026
    I would say he disconnected the horn. You don't hear it, but it is likely still going off.
    BiomedO1 likes this.
  14. BiomedO1
    4,374
    2,302
    Left Coast
    If it's an after-market alarm - it'll have it's own horn. If it's an OEM alarm your horn isn't going to work.
    ASRDogman likes this.
  15. Carall
    316
    104
    Harrisonburg, VA
    But the alarm horn on gen 2 is located somewhere behind the right fender.
  16. ASRDogman
    7,920
    4,026
    But this is the THIRD GENERATION chat forum......
    Grit likes this.
  17. Carall
    316
    104
    Harrisonburg, VA
    Oh, my bad!
    Now i have a question. Where is the alarm horn located on gen 3 prius?
  18. alexk345
    46
    india
    2010 prius is my car. Now he disabled alarm or solved the problem? Now you guys telling he did not solve it?
  19. ASRDogman
    7,920
    4,026
    I am not sure what he did. I said he likely disconnected the horn.
    I "think" the alarm horn "might" use the standard horns, but I am not sure.
    I "should" be a separate horn, but I don't know for certain....
    He could have pulled the fuse for it....
  20. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Sub forums are only suggestion, post anywhere that make you feel good
