Alexa Echo Auto
Discussion in 'Prime Main Forum (2017-2022)' started by teddy2655, Sep 11, 2019.
  1. teddy2655
    teddy2655 New Member
    san diego
    2019 Prius Prime
    Has anyone here have the echo for Automobile? i got the invitation to buy but not sure the use of it and how to mount it. Is it worth to try on the Prius Prime advanced?
  2. schja01
    schja01 One of very few in Chicagoland
    1,744
    1,162
    Chicagoland
    2018 Prius
    Mine is coming today. They force you to buy a vent mount. Heck it’s not all that expensive and Amazon’s return policy is great.
  3. Bob Comer
    Bob Comer Active Member
    708
    457
    South Carolina low country
    I got mine in awhile ago but haven't tried it yet, I plan too real soon. I don't think I'll be mounting it on my vent, but we'll see. I hope it will be good for audible books...
  4. Rob43
    Rob43 Senior Member
    1,373
    1,047
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Teddy, Welcome to PriusChat !
    Our Prime has been running the Alexa + vent mount for ~6 weeks, it works great. The only limitation is if you loose your signal when you travel through outlying areas with bad reception.
    Rob43
    PS, If you have a 240v outlet near your Prime, you can charge up in 2 1/2 hours for less than $50 dollars.
  5. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    You don't need a vent mount, I have mine attached directly to the flat-ish part of the dash (pardon the blurry pic):
    Pros:
    • Its voice sensitivity appears better than Toyota's
    • Access to the Alexa skills
    • Far better integration with your phone absent native Android Auto/Apple Carplay capabilities
    Cons:
    • Can't change the wake word (stuck with "Alexa")
    • There aren't a ton of Alexa skills that are actually useful (but I can get my Echo Auto to meow at me)
    • Actually getting the Echo to execute all but the simplest commands is a huge pain. I regularly get frustrated enough that I switch back to operating my phone by hand
    Before buying the Echo Auto, I would highly recommend looking through the list of Alexa Skills to see if and how many you think you would actually use while driving.
    Also, to any other Prime Echo Auto owners, if you have any good tips or skills for using the device, please let me know.
    skirmish and Bob Comer like this.
  6. lowkey6
    lowkey6 Junior Member
    17
    MD
    2019 Prius Prime
    Mine arrived last week - came with the vent mount for $25(though I think you can put in near the Qi charging area and it still picked up my voice fine). Ultimately I was disappointed by it and returned it. Did not seem to work well at all - it basically needs the Alexa app on your iphone to handle most functionality. For me, it seemed easier to just use the USB input, say "Siri, open amazon music (or alexa app)" and control from there.
    It also did not seem to work well with opening various podcasts, changing XM stations, etc. I got a lot of error messages or "this does not support" when testing out basic functions I would want to use.
    Perhaps I set it up incorrectly, but I have several echos and dots that I use a ton and this one did not seem to be a value add for me at all.
    noonm likes this.
  7. Rob43
    Rob43 Senior Member
    1,373
    1,047
    2013 Prius v wagon
    Wow, how interesting, ours literally works just like the Alexa's in our home.
    Rob43
  8. OpusFuller
    OpusFuller Member
    31
    47
    PA
    2018 Prius Prime
    I bought the echo auto. It came free with a vent mount. What I did was attach some 3m double sided sticky pads and stuck it under the flat part that's above the wireless phone charging pad. If you look at the shift knob, follow that down and it will curve back into a pocket. I stuck it on that ceiling part. I hid the cable under the center console and ran it all the way into the rear and plugged it into the 12v plug. No wires are exploded and Alexa is hidden from view.
    skirmish likes this.
