Alignment at Toyota or Independent Tire Shop ???
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dorf, Apr 26, 2008.
  1. dorf
    dorf Member
    132
    Little Rock
    What is everyones experience and or recommendations for alignment.
    Purchase tires and align at Toyota or at Independent shop ???
    I'm Just trying to minimize the hassel factor.
  2. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    I would lean towards a professional tire shop before the dealer unless it is a warranty item.
    Look for a shop that uses Hunter equipment. The rear of the Pri needs shims to make adjustments I am told. It takes a seasoned pro to do the job right. Dealerships may or may not let inexperienced techs work on that.
  3. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Alignment can be more difficult on the Prius, especially if the rear beam axle is out of spec.
    If you want to have some fun, ask the tire shop how they intend to do the Zero Point Calibration of the steering wheel. If you get the classic "deer in the headlights" look, that's normal
  4. dorf
    dorf Member
    132
    Little Rock
    OK-Thanks for the advice. I was sort of leaning towards an independent shop.
