Alignment b4 or after new rims/tires?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Higgins909, Dec 3, 2018.
  1. Higgins909
    Higgins909 Member
    257
    58
    I'm still poking around about getting new tires or new tires and rims (can't remember the tire size, but rim was 17") or trading in the prius. (I can not get the seating and steering wheel to a comfortable position) Then I ask, how do I get it aligned? I heard something about the Steering wheel having to be centered specially at a Toyota dealer?
    Thanks,
    Higgins909
  2. Mendel Leisk
    38,729
    The steering wheel is not centred with wheels straight ahead?
    If so, could maybe be corrected with equal-but-opposite rotation of the tie rod adjustment nuts.
    #2 Mendel Leisk, Dec 3, 2018
    tankyuong likes this.
  3. Higgins909
    Higgins909 Member
    257
    58
    It's fairly straight. But in order to drive straight, I might have to turn left ever so slightly. It likes to pull right after I hit a pothole quite a while ago. I was trying to look into it once and read something about the electronic power steering center having to be programmed.
  4. Mendel Leisk
    38,729
    Try switching left and right wheels first. It's relatively easy, so worth a try. There's a thing called conicity that might be fixed by this action.
  5. Higgins909
    Higgins909 Member
    257
    58
    I finally did this. I've only put maybe 20 miles on a couple roads but I think it's fixed it for the most part. It might pull left ever so slightly. Need to drive it more to see. Does this mean my tire and or wheel is messed up?
  6. Mendel Leisk
    38,729
    We had this on a previous vehicle, with tires about half-worn. I'm not sure of the root cause, just that it's a wear condition called "conicity" (google for more explanation). Swapping the wheels side-to-side can kinda fix it. Eventually the tires wear to where they're replaced, and maybe time to switch brands, I'm not sure though.
  7. audiodave
    audiodave Active Member
    787
    268
    US
  8. ASRDogman
    ASRDogman Senior Member
    6,092
    3,273
    You're caster is off, you need an alignment. Best to do with new tires.
    #8 ASRDogman, Jan 1, 2019
    frodoz737 likes this.
  9. Grit
    Grit Senior Member
    6,148
    4,058
    Wilkes Land
    Trade. You won't have to worry about EGR, manifold and sudden inverter death anymore.
  10. Mendel Leisk
    38,729
    Geesh: @Higgins909 says he swapped the fronts and thinks it's cured; maybe it is?
  11. ASRDogman
    6,092
    3,273
    If the car pulls, or drifts to one side, say right, and you switch the front tires and it now pulls left,
    it means you drove that way long enough that the tires are unevenly worn, because of the caster being out of alignment.
    If it still pulls right, it just means you have not driven it long enough that the tires have worn yet.
    Either way, you need an alignment. Maybe even have some worn bushing.
    You should check, or have the bushing, and suspension parts checked for wear, and replaced if needed.
    Then have an alignment.
    #11 ASRDogman, Jan 1, 2019
    audiodave and frodoz737 like this.
