Alignment: has to be done at dealer?
Discussion in 'Gen 2 Prius Main Forum' started by wrothgar, Aug 19, 2022.
  1. wrothgar
    wrothgar Junior Member
    77
    16
    oakville, ontario
    Do I have to get an alignment (gen ii) at a dealer? Canadian Tire is telling me they won't touch the Prius because of a service bulletin.
    49,492
    not at all, no idea what service bulletin they are referring to. any good alignment shop should be able to help you
  3. PriusCamper
    PriusCamper Senior Member
    11,105
    4,518
    Pacific Northwest, USA
    Gen2 had a problem with the steering rack being loose and had a recall that added a couple bolts to where the rack connects to the steering wheel rod. If you have a used Prius, that work may of been done already... But more to the point, Canadian Tire is just making up excuses to not do the work.
    And do you even need an alignment? Uneven tire wear? Doesn't drive straight? As in nothing to worry about if you don't have significant symptoms.
    Mendel Leisk and bisco like this.
  4. Mendel Leisk
    38,727
    Yeah this.
    I think the only thing easily adjustable is front toe; everything else it'd be "you'll need new parts".
    Simbaboy likes this.
  5. wrothgar
    77
    16
    oakville, ontario
    Well, I need new shocks....and just changed a ball joint and a tie rod.
