Alignment question after new tires
Discussion in 'Gen 2 Prius Main Forum' started by hans_fh, Dec 8, 2010.
  1. hans_fh
    hans_fh New Member
    51
    Hello guys!
    I just a new set of tires from Sams Club today. And I called my dealer and asked them about the alignment. They said the alignment costs $35. When I asked them if it is for the front and rear, they said it's for the front only since the rear is not adjustable. Does it make sense? Thanks!
  2. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Toyota does not have a procedure or parts to adjust the rear suspension alignment other than installing new parts and hoping they are better. The rear camber and toe can be adjusted but requires some special tapered shims that are not available through Toyota. You would either need to do the rear yourself or find a good alignment shop, most regular high volume alignment shops will also tell you the rear is not adjustable.
    Odds are your dealer will only adjust the front toe because adjusting the front camber requires some different Toyota supplied bolts and it seems like some dealers either don't know about them or don't want to bother with them.
  3. Patrick Wong
    18,200
    6,474
    Limited camber adjustment can be achieved with the existing strut bolts. If more is required, then special bolts can be installed.
  4. macmaster05
    macmaster05 Senor Member
    4,050
    729
    Sears is correct - most all places do not set the rear camber and toe. They will measure it, however, to check that it's in spec. It's nice they told you a fair price though. Most places would charge you the full $50-80 and never tell you they didn't align the rear.
    The good news is that the rear specs have a much wider acceptable range than the front. So it's very rare that you'll even need anythinf adjusted there. Even after I lowered my car my rear toe and camber was in spec, thank god!
    As for the camber being adjustable without a camber kit: That's definitely true, but most typical tire shops like Sears, Firestone, etc won't adjust that for you, even if you tell them the procedure. You'll probably need to go to a custom alignment shop for that, or the Toyota dealership, who I hate fussing with.
  5. hans_fh
    hans_fh New Member
    51
    So the dealer's alignment work will just be enough for my car, right?
  6. don_chuwish
    don_chuwish Well Seasoned Member
    816
    182
    Southern Oregon
    Hopefully yes, good price and better than nothing certainly. Be sure to have them show you the printout of the readings before and after. Even if nothing can be done for the rear I'd still prefer to see how it measured. If they won't even measure and report then maybe consider a full service tire shop instead.
    - D
  7. Optimus
    Optimus Member
    260
    17
    Many vehicles cannot be aligned in the rear, and this is a pretty common situation. As previously mentioned, they can measure it, but they usually can't do anything about it other than replace some suspension parts and hope it works. There often aren't any parts that can actually be truly adjusted on the rear of many vehicles, thus no adjustment (e.g. alignment) is possible.
  8. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    The bad news is that the rear alignment specs are sloppy so they have an out when rear wheel alignment is checked. It's common on cars with cheap rear suspension.
  9. macmaster05
    4,050
    729
    Hmm yeah. My point was that a rear toe of .35 is within acceptable range, whereas even .1 would be out of spec for front toe.
  10. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    My point was that the rear spec is sloppy for the convenience of Toyota, not because it's a good spec. There is no good news there. Most cars with the form of inexpensive rear suspension that the Prius uses are in the same boat.
    What makes is worse is that Toyota tells us that it isn't adjustable when it is adjustable with inexpensive aftermarket parts.
  11. macmaster05
    4,050
    729
    Haha ok I gotcha. The thing is, if it's good enough for Toyota, it's good enough for me!
    If it really bugs you, you could always go to frame shop and they could tweak it for you.
  12. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    It's on my to-do list. I'll do it myself.:rockon:
