Alignment Shims
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by The Critic, Nov 28, 2011.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,332
    CA
    After checking the alignment at the 10,500 and at the 15,500 marks (and obtaining the same rear toe readings both times), it is clear that the chassis and suspension parts have "settled" on my Prius and that an alignment shim will be needed to properly align my car.
    Although my rear toe is technically in-spec the LR toe is not ideal. It is likely responsible for the 0.09 thrust angle and the slight "unsettled" feeling that I get from the LR corner.
    I have already ordered a pair of SPC 75800 shims and will cut and install them and have Firestone recheck the alignment under the lifetime alignment plan.
    However, on this car, has anyone tried installing shims? What will it entail? I think it may be a bit more difficult due to the rear caliper setup and the need to perform a linear solenoid calibration with Techstream whenever the brakes are touched.
    If anyone has any experience with this, please let me know.
    Thanks.
  2. ozarkretiree
    ozarkretiree Member
    72
    26
    Missouri
    Four Touring
    I went thru this issue between Firestone and Toyota. F saying they could not bring the car into the T specs without shimming and T saying it the car was in spec. The T dealer printout showed readings out of spec but within tolerance (?). F cut me a deal since I buy all my tires and service there and also sold me the lifetime 4 wheel align. Good investment as I am on my 4th set of tires (always BrStone OEMs).
  3. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
  4. The Critic
    3,193
    2,332
    CA
    I have both the EZ shim and the shim spacers already. I just have not decided if I should install them since one side is at 0.22, while the other is at 0.09. The difference is not enough for it to become an issue. I'm sure the "tram lining" I currently get from the rear would go away, however.
  5. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
    My Gen2 would not track correctly, tramlining, wandering all over the road, poor resistance to cross winds, etc. The problem was not enough toe on one side in the rear, similar to what you have. I ended up increasing the toe to around .20 on each side which solved the problem. I couldn't find anyone willing to do the job so I made my own shims and installed them myself.
    But the Gen2 had drum brakes on the rear so installation was very easy. Just take 4 bolts out and slip the shim in and put the bolts back. As you mentioned having disk brakes you will need to shim the caliper.
    The difference in handling on my Gen2 was greatly improved so I would say go ahead and do it. Looking at your alignment sheet I think I would just do the right hand side.
    EDIT:
    I checked my maintenance manual cd for linear solinoid calibration and found this on page 942:
    "(a) Perform initialization and calibration of the linear solenoid valve when the brake booster with master cylinder (skid control ECU, brake actuator or pressure sensor), brake pedal stroke sensor or brake pedal is replaced."
    Maybe shimming the caliper would not require a linear solenoid valve calibration. I also noticed there are two procedures, one using the Techstream, the other not using it.
  6. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    I shimmed the rear of my UK gen2 Prius to correct excessive camber and found that calliper shims are not required. The calliper moves with the brake back plate staying in alignment with the disc, that is the complete hub backplate calliper assembly are all moved together as one, away from the axle beam assembly by the shims.
  7. wigwag
    wigwag Junior Member
    CA
    Well yeah, I have had some experience with this shim business- all of it bad but I don't have enough evidence to blame the shim. My 2010 was showing abnormal rear tire wear by about 5k because the rear alignment was way outside of Toyota's absurdly wide tolerances. The axle should have been replaced but Toyota refused and installed a shim on one side. I came out of the stealership with a readout showing that all was well but the car promptly destroyed both rear tires. Back on the rack the readings were even crazier than before. What happened? I have a good idea but in the interest of brevity I'll just say that the axle and all tires were replaced and I motored out the door with yet another readout claiming all was well. Due to time and health constraints not enough miles have elapsed for me to make any judgement about the success of the latest operation. The post mortem leads to a couple suggestions; instead of breaking the "petals" out of the shim, drill holes with a dremel tool just the size of the bolts to leave more intact bearing area to more evenly distribute the "crush" forces on the shim. (I suggest buzzing holes with a dremel burr or similar rather than drilling because these shims are a brittle mix of metal particles suspended in hard plastic and I suspect drilling would shatter the shim.) As to the caliper-to-rotor alignment conundrum I would suggest feeler-gauging the caliper support to rotor clearance before disassembly and duplicating this dimension with shims when reassembling. Don't bother with the shim manufacturer's shim washers- they are overpriced bits of useless plastic with the wrong dimensions for this car. Based on comments from other users of these humorously named E-Z Shims you will want to be sure to retorque the bolts a time or two (or three) because it seems that the plastic-metal mix "flows" for a while before eventually stabilizing.
