Alignment
Discussion in 'Prius v Main Forum' started by beachgeek, Jun 12, 2017.
Tags:
  1. beachgeek
    beachgeek Member
    102
    24
    2013 Prius v wagon
    How often - or perhaps at what mileage - do I need to have my tires aligned? At the dealer today I was advised I have "a little" "out side edge ware." They wanted me to get an alignment. Since I heard them tell two others the same thing I took a pass.
    Since I get the tires rotated regularly wouldn't the wear be on the inside one time and the outside the next?
    Is that different from a front wheel alignment?
  2. Air_Boss
    Air_Boss Senior Member
    4,220
    1,188
    New Yawk
    Sounds like the dealership's alignment line of business is "a little" light...
  3. beachgeek
    beachgeek Member
    102
    24
    2013 Prius v wagon
    Definitely my thought.
  4. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    Translation: Our cash flow from the service department is short this month; can we get an extra $100 or so from you?
    Air_Boss likes this.
  5. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Outside edge wear is often a symptom of low air pressure. Maybe that is another reason the service people tend to reduce my PSI when they do maintenance on my Prius.
    JeffD
  6. Air_Boss
    4,220
    1,188
    New Yawk
    Exactly, which is why it makes sense to check TP after receiving the car back from the dealer --- no matter you told them to maintain 41psi Front / 40psi Rear.
  7. Kenny94945
    Kenny94945 Active Member
    857
    433
    Sausalito
    2016 Prius v wagon
    It all depends...handling, long wear or ease of steering return to center.
    Low pressure tends to wear both inner and outer edges.
    High pressure wears the center.
    Rotation a good thing yet which ever wheel is out of align will wear in the same area/ corner.
    Some tire models only front to rear others four corner rotations are spec'd.
    OP may be thinking of actually swapping the tires on the rims for inner and outer wear equalization.
    Can be done, yet you have the mount and balance expense added.
    When to align?
    Some say yearly.
    I say when you notice a wear or handling issue or at replacement tire time to be prudent.
    A good/ caring alignment mechanic is a valuable find.
    I'd pass on the dealer recommendation in this case too.
    Good luck.
