All 4 cylinders misfiring after getting gas?
Discussion in 'Newbie Forum' started by bethandkenny, Aug 4, 2016.
  1. bethandkenny
    bethandkenny New Member
    2003 Prius
    Hi. I hope you have suggestions. I have a 2003 Prius with 212000 miles. I drive about 300 miles a day. I've never had a problem with my car.... Until yesterday. I stopped for gas, pumped, got back into my car and started it..... And horrible knocking noise.... As if I had no oil in it. I immediately shut it off, and checked my oil. Everything was perfect, and oil change just a month prior. There was an advanced auto right next door, so I asked them to run diagnostics, which they did and showed that all 4 cylinders were misfiring. I spoke to a local mechanic, and he said he was sure it was the gas. The guy at advanced assured me that the gas station has the best gas around, oddly really pushing that it can't be the gas. I had the repair shop tow it. Within a half hour the mechanic called and said he siphoned the gas and no water and it smelled good. He also told me it wouldn't start. So I had it towed from Clewiston to fort Myers for $250 to a Toyota dealership. After doing a half hour diagnostic they call and tell me I need a new hybrid battery!!! My battery was at full charge, I have always gotten 42 mpg consistently, and have always ran full charge (less the top indicator line). There was no warning lights of any kind that it was failing. I always keep my screen on energy.... To make sure battery always working. When she called from Toyota, she said they also had to charge the 12v... That the hybrid battery must've killed it.... What am I an idiot?! She said its probably because the car day so long.... When is the last you even drove this car?!... She asked! I said well 300 miles on Tuesday and another 40 yesterday to the had pump, which is where it stopped. I really don't think my hybrid battery just went.... Could it be a computer thing causing it to throw this code? Could it be I just need a new 12v?... Though that one is only 6 months old. Any thoughts? They and $3200 for the battery. I think they've lost their mind. Also, she refused to let me speak to my service tech. Thanks for your help people. Just very frustrating, Beth
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    First, the hybrid battery should have nothing to do with the engine knocking noise and misfiring on all 4 cylinders that Advance Auto reported.
    Second, get the DTC (Diagnostic Trouble Codes) codes from your Toyota dealership and post on here. It is difficult to help troubleshoot without the DTC's.
    Rebound likes this.
    49,522
    welcome! it sounds like you own a 13 year old car with 212,000 miles. all the best!(y)
    fwiw, my lawn mower wouldn't start, and the garden center repair shop said the gas was more than a month old. 50 bucks.
  4. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    I totally agree. This diagnosis does not make much sense. The Prius has a computer diagnostic connector called OBD. The dealer should be able to give you the failure codes that the car is showing via OBD. If they refuse to give you the codes, (such as "P0400") I think you shouldn't do business with that dealer. There are lots of possible causes, so let's see what the diagnostics point to.
