All my Mini VCI are burning
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by b100, Mar 22, 2017.
  1. b100
    b100 Member
    141
    74
    Netherlands
    Hello,
    Ok, this is something strange.
    My 3rd mini vci is burned to........
    I really don't understand why all my mini vci's are burning.
    When i put one in my prius and start the software, they burn.
    Literally burn and smoke.:eek:
    An other standard OBD reader works fine
    Someone the same problem
  2. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,139
    1,598
    Iowa
    My first question is are the products all from the SAME source.
    If so, I would suspect that might put you on track for an answer to your own question.
    I've had two different ones from different suppliers. Neither had an issue. However, for my second one, I spent nearly double ($38 USD) to get one that claimed to be much better built than the rest of the herd.
    It does seem to be a little more "hefty."
    Oh, the first one I got arrived and the plastic casing was cracked. I used it once as it was an emergency sort of thing -- I had to diagnose that day. It worked, but I sent it back the same day for a refund.
    b100 likes this.
  3. b100
    b100 Member
    141
    74
    Netherlands
    Thanks for the advise, but i found the solution.......buy a new laptop.
    The USB port in that thing was totally messed up:confused:
