All of dashboard lights became on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Azhar, Aug 14, 2018.
  1. Azhar
    Azhar New Member
    Pakistan
    I have 2007 prius.yesterday while driving first the AC stopped working then after some time all of dashboard lights like triangle,engine,ABS,hand brake etc became on with a beep sound.when i came home i plug off the 12 v battery terminals and all the lights were off and car was normal.what could it be?????
  2. hchu1
    hchu1 Active Member
    316
    127
    Houston, Tx.
    2014 Prius v wagon
    Check your inverter water pump, open the reservoir by taking the cap off, then push on/off button twice without touching the brake. If the pump is working you should see water moment and hear the pump on, if not, then the pump is likely dead. Replace the unit, if you haven't replaced the fluid before, now would be a good time to do so.
    bisco and ITBland like this.
