All warning lights on, high battery voltage
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cra205, May 22, 2023.
  1. cra205
    cra205 New Member
    I have a 2011 base Prius. It is not recognizing the smart key but if I hold the key to the start button it will start. Once it starts, it runs fine but all the warning lights stay illuminated and the message center toggles through the various warnings (maintenance required, check hybrid system etc.) I suspected I have a a bad 12v battery as what I have read here indicates that can cause strange electrical issues. When I check the batter voltage at the fuse box with the car off, it’s almost 17v, car running is 21v. Has anyone else seen this? I am still thinking it could be the battery, but wanted to ask before spending $250 on a hunch. Thanks in advance for your input!
  2. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    Those are strangely high voltages. Check with a different meter to see whether you get the same values.
  3. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    Shocked that all 12v components are still working running on 21v measured with car on ready :eek:
    51,155
    usually, that's a dead fob battery, so start there.
    i suspect something is wrong with your multimeter, or it's on the wrong setting
    CR94 likes this.
  5. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    ...Or the multimeter's battery is failing. I have a cheap multimeter that will appear to function, but shows falsely high voltages if its internal battery voltage drops too low.
