all warning lights
Discussion in 'Gen 2 Prius Main Forum' started by Arqum, Aug 26, 2017.
  1. Arqum
    Arqum New Member
    pakistan
    no error on scanner, all warning lights on except vic light, not going to ready mode, engin is not starting reset many time by unplugging 12v battery. .also charged the 12 battery from battery shop
    please help getting from last two days
  2. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    What did you use to read the codes? It probably can’t read hybrid system codes. If you want to read the codes yourself get Mini-VCI.
  3. Arqum
    Arqum New Member
    pakistan
    49,594
    welcome!
    what is the static voltage of your 12v after the car has been off a few hours?
  5. Arqum
    Arqum New Member
    pakistan
    10 V, when i switch on goes to 9.
  6. Arqum
    Arqum New Member
    pakistan
    10 V on off , it goes to 9V when switch on
  7. bisco
    49,594
    you need a new battery.
    Raytheeagle likes this.
  8. Arqum
    Arqum New Member
    pakistan
    i placed new battery ..but same ..:(
  9. StephenJ
    StephenJ Member
    186
    Birmingham, AL
    Four Touring
    Just for clarification sake, the voltage you said is from a new battery? As in brand new and just installed and it's reading 9-10v? That voltage is to low
    Disconnect the battery (both positive and negative) from the car and then test it. This can help determine if there is something electrical on the car that's pulling down the battery real bad.
  10. Arqum
    Arqum New Member
    pakistan
    this is for old one, new battery have full 12 V.
  11. Fred_H
    Fred_H Misoversimplifier
    554
    476
    28
    Germany
    Check the brake pedal switch.
    If the brake pedal switch is misadjusted, or has a bad connection, or is defective, then pushing the power button will cycle through "accessory" mode, "ignition on", and "off", but never go to "ready".
