All windows except driver window don't work
Discussion in 'Newbie Forum' started by Frog21, May 31, 2025.
  1. Frog21
    Frog21 Junior Member
    Illinois
    Hi all, recently both of the cigarette ports went dead after what I believe a faulty FM transmitter blew the front one. I replaced both the fuses after a few tries and they work now. But now the window controls only make the driver's window go up and down. The buttons for the rest of the windows don't make their respective windows go up/down. Basically the other three windows don't roll, and even using each individual door's button doesn't work.
    Thoughts? It's a 2006 Prius with 212k miles
  2. Tideland Prius
    16,427
    And you checked that the window lock-out button wasn't accidentally pressed on the driver's door?
  3. Paul Gregory
    Paul Gregory Senior Member
    1,362
    356
    Alberta
    2024 Prius Prime
    XSE
    Isn't that for locking out other windows, besides the drivers?
  4. Tideland Prius
    16,427
    I thought Toyota had a silly setup where it locked out the passenger window switches on the driver’s side as well.
