Alloy wheels = More MPG?
Discussion in 'Gen 2 Prius Fuel Economy' started by KelleyLafitte, Mar 8, 2016.
  1. KelleyLafitte
    KelleyLafitte New Member
    Tampa, FL
    I bought a base model 06 about a month ago, wondering whether getting the nicer (and apparently larger?) alloy wheels would be worth it. They look a lot better and I'm wondering if they'd fit, if the fuel economy would be improved/ impacted, and what other considerations might be taken when looking at purchasing new wheels for this model. I know there's plenty of threads for tires so I'll look to those for advice there.
  2. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Stock Prius alloy wheels are very light. Almost any other wheel is heavier. Fitting larger rim will make it even heavier since rim gets bigger and amount of air (that’s weights almost nothing) gets smaller. And bigger rims are normally wider too.
    Weight of the wheel matters a lot more for fuel economy than other weight since it’s unsprung and rotating mass.
    uart likes this.
  3. KelleyLafitte
    Tampa, FL
    Thanks for the input, kind of a noob when it comes to this so I wanted to ask first before whipping out the card
  4. Kevin_Denver
    Kevin_Denver Active Member
    581
    422
    Denver, CO
    valde3 hit the basics. As far as rims go, lighter is more fuel efficient. However what will have a larger impact on fuel economy is the tires. Properly inflated low rolling resistance tires can significantly reduce fuel economy. However low rolling resistance tires often have tradeoffs - such as worse snow handling.
  5. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    snow handling isn't a factor in tampa, but yes, lighter wheels and LRR tires inflated to 40psi will give you better mpg. there are several choices for very light 16" wheels. bigger than 16" not too many. I have ecopias, and they give good mpg, but handling isn't all that.
