AlphaTherm Washer Fluid heater
Discussion in 'Gen 3 Prius Accessories and Modifications' started by chrisj428, Aug 14, 2014.
  1. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    Does anyone have experience with the AlphaTherm washer fluid heating system? I'm thinking I would like to install this before the snow flies.
  2. pauerbach
    pauerbach Member
    101
    34
    Why not just get cold weather washer fluid? It's a heck of a lot cheaper and simpler. Worked great for me in 15 F weather. How cold does it get where you are?
  3. Squirt
    Squirt Member
    204
    47
    Los Angeles
    2014 Prius Plug-in
    Up to you, but looks like a waste of money to me. I used to live in MN, and never had an issue, even at sub zero temps.
    Venue 8 Pro 5830 ?
  4. chrisj428
    680
    144
    35
    Vernon Hills, IL
    It will hit 0°F from time to time. And, I don't have covered parking.
  5. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    No experience with the heater, but I'd try the cold weather fluid before I spent the money. Ours froze when we lived in Colorado Springs and I found they make the cold weather stuff. No problems after I replaced the fluid.
  6. Squirt
    Squirt Member
    204
    47
    Los Angeles
    2014 Prius Plug-in
    You can also make your own cold weather fluid by adding a tablespoon of isopropanol to a full tank of normal fluid.
  7. Mendel Leisk
    38,706
    I think the idea with that heater is NOT for preventing freeze up in the reservoir. It's only on (sensibly) when the ignition's on. I think it's purpose is to ensure the fluid's quite warm when it hits the windshield. It might be beneficial: even the highly freeze protected stuff can freeze onto the windshield, with temps barely below freezing. Still, especially with our west coast climate, I'd give it a pass.
    FWIW, I never use the "summer" stuff, use freeze protected year round. Don't use much in spring and summer, the fluid will sometimes sit in there a whole year.
  8. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    You're right, Mendel, I should have tried the link first. At the price I saw on Amazon, I'd pass. In my experience in Colorado, it didn't take that long to defrost the windshield and I don't remember ever having a problem growing up in Wisconsin once the windshield was defrosted, my car was always parked outside overnight.
  9. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    Many, many years ago I extended the washer hose and wrapped the extra around a cabin heater pipe a few dozen times. If I recall correctly I also added a felt cover to the wrap as a layer of insulation.
    It worked well.
    I also built a channel onto the bottom of the windscreen and a little hose to direct rainwater into the washer bottle to keep it topped up.
    That also worked well.
