Alternate Oil Change - Filter only?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rae Vynn, Jan 30, 2010.
  1. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    So, we were discussing today the concept of just changing out the oil filter and topping off the oil (we use Mobil 1) at alternate 5K oil change intervals.
    Does anyone do this, do you think it would be okay to do, etc.
    The reason we're discussing it is that it seems pretty darned wasteful to change all the oil, because it's synthetic, doesn't smell burnt, and seems still pretty clean at 5K, and we'd like to conserve some resources.
    anyone? Buehler? Buehler?
  2. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    Do further research at Bob The Oil Guy's website.
    At the first filter-only change, take an oil sample & have it analyzed. The results will tell you if it's safe to postpone a full oil change.
  3. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    58
    Fullerton CA
    Purolator puts out a filter, PL10241 that works just swell as a 1x oversize filter for the 2nd generation Priuses (Prii?)
    The PL20195 works just swell as a 2x oversized filter.
    I use the PL20195 and Mobil 1 EP, and change both at 10k intervals.
    I could probably go as long as 15k on both the oil and the filter, but I get a little nervous.
  4. dogfriend
    7,512
    1,189
    Carmichael, CA
    This is actually the reason that the oil analysis companies like Blackstone et. al. exist. Oil can be a big expense in industrial equipment or heavy duty truck fleets, so instead of changing on a time or mileage interval, you have samples tested to see how the oil is doing and you try to extend the life of the oil as much as practical.
    It makes a lot of sense when you are using a lot of oil (a big truck fleet), economically it may not make as much sense with a small amount oil like the Prius uses because of the cost of testing, but it does conserve some resources.
  5. Bob64
    1,540
    93
    Virginia
    Since the prius in europe has a ~10k mile oil change interval, i'd say its pretty safe as long as you use synthetic oil.
  6. Jchendy
    Jchendy New Member
    SC
    AMSOIL sells a oil that is good for 25K, you should still change the filter at 5K
  7. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    Is that 10K kilometres, or 10 K miles? Ten kilometres is about 6 miles, so 10K K would be 6,000 miles, thereabouts - close enough to the 5K miles US Toyotas call for to be within perimeters.
    Thanks all for your input! Rudy is getting his regular oil change today - we'll be looking into this for future oil changes.
  8. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,151
    1,701
    Mars Hotel
    According to my father -- in the "olden days" they always alternated during changes. But they would change the oil, but not the filter. He still does it this way and his vehicles of his vehicles go way past 200,000 miles.
    He gave me some explaination, but not sure if it is true or not that the oil in the old days was "not as good" and didn't last as long. Plus, the oil was very cheap to buy. Filters, on the other hand were expensive. I know it doesn't answer this question, but I thought it was interesting, anyway.
  9. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Miles. The normal oil change interval (Oil and filter) for a Prius in the EU, running ACEA spec motor oil, is no more than every 12 months or 10,000 miles
    Better rated oils used in German cars can extend this to 24 months or 30,000 miles
    If you have a choice of skipping oil changes but change the filter, or skipping an oil filter change, just skip the oil change itself. You gain NOTHING by leaving an old, possibly clogged, oil filter
    That was the wrong way to do it. It wasn't uncommon for filters to plug, so unfiltered oil was sent to the motor. Back then, tolerances were much looser so perhaps it didn't matter
    My dad would just change the oil filter and not the oil itself, but he always used Heavy Duty oil - like the kind you would use in a semi truck - in all his cars. No problem with getting 200,000 miles out of an early 1970's car
  10. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    Used oil analysis testing is your friend. At least to gain an understanding of how your oil and filter performs, then you can decide how to proceed. My recent results showed that the Amsoil 0W-30 will easily be OK up to, if not past, 10K miles. I'm also using the Amsoil filter and it should be good up to 20K miles. With maybe one more test at 10K miles on this current oil I'll know for sure.
    - D
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    Correct, only a used oil analysis can tell you how the oil and filter are performing
