Alternative access to Service Menu without toggling the light switch 3 times
Discussion in 'Gen 3 Prius Audio and Electronics' started by GGGF, Sep 26, 2018.
  1. GGGF
    GGGF New Member
    sd
    Hello All,
    I have Toyota touch2 which I`m trying to access it's Service menu for upgrade purposing.
    Only thing is, the system is not connected to the car, and I need an alternative way of accessing, or faking for that matter the toggling of the light switch which grant access to the hidden Service Menu.
    I searched all over the place and couldn't find a solution.
    My system does not have the extension module, it it's any matter.
    toyotamaps.online/map-updates/toyota-touch-and-go-navigation-update
    Assaf.
  2. Mendel Leisk
    38,733
    Welcome. Just a little puzzled, and it might help responders: sd equals Sudan??
  3. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    If you're just updating the maps/firmware (which I'm guessing you are from your link) you don't need to access the service menu on the Touch 2. I just updated my head unit a few days ago. There's a whole post on it here: Map update 6.11.2 | PriusChat
  4. GGGF
    GGGF New Member
    sd
  5. The Professor
    598
    809
    UK
    Excel
    So why aren't you using the firmware in the way I mentioned in post 3?
