1. socratesthecabdriver
    283
    30
    greece
    I AM LOOKING IN TO ADDING gas to my prius LPG they call it here in greece. this place has instaled this alternative fuel to a 2006 already ,the instaler is getting information for the gen 3 and will tell me if it is posible to do ! i also have to check with toyota on how much of the warranty gets thrown out if i do decide to install it! a liter of gasoline in greece is 1.50 euros verssus .60 cent for gas
    this link is the governments approved installers site YGRAERIOKINISI | 5th GENERATION
    and these are picks of the work done to one 2006 TOYOTA PRIUS
    i am just going to copy paste part of it
    The new liquid injection JTG system is ICOM patented, with euro 4 homologation.
    ICOM JTG- Common Rail system permits to take profit of the low cost of LPG, which is around half than petrol. With JTG System the vehicle high performance is always ensured. ICOM JTG – Common Rail has a reduced number of components. This permits a non invasive installation on the vehicle engine and a long term programmed maintenance (around every 15.000 miles).
    Once again bringing the Ygraeriokinisi lead for the first time in Greece the new liquid spray gas ICOM JTG, a patent from the Italian company Icom Spa. It is more advanced than previous systems spray gas and perhaps the best system in the global gas market .. It is certified with the stringent emissions standards of the European Union EURO4. Still be certified by laboratories approved European-control centers, and in accordance with the requirements of the UN committee responsible for Europe and the European Union. Also approved by the Division of Motor Vehicle Technology Hellenic Ministry of Transport and Communications.
    [​IMG] Responding to the constant technological developments, Ygraeriokinisi which is the exclusive representative in Greece, is in direct cooperation with the Italian company visits-awareness seminars, certification and training of technicians on concerns that the newer products.
    icom®
    Revolution of G. P. L.
    BENEFITS 5th ICOM JTG GENEIAS LIQUID SPRAY
    √ Lower pollutants..
    √ Profit from the low price of LPG LPG is almost half the price than that of petrol..
    √ Easier installation
    √ Fewer components..
    √ Without lung..
    √ Without planning..
    √ Increase horsepower than the gasoline
    Dynamometer vehicle (VW polo 1.4) with an ICOM JTG 5th generation.
    *Blue line of unleaded petrol
    *Red Line LPG gas
    BOTTLES 5th generation
    icom®
    The bottles have built a great little pump depending on the horsepower of the vehicle.
    [​IMG] BOTTLES ICOM CYLINDERS JTG 270Χ840X42LIT
    BOTTLES ICOM CYLINDERS JTG 270Χ940X48LIT
    BOTTLES ICOM CYLINDERS JTG315Χ840X57LIT
    BOTTLES ICOM CYLINDERS JTG 315Χ940X64LIT
    BOTTLES ICOM CYLINDERS JTG 360Χ780X67LIT
    BOTTLES ICOM CYLINDERS JTG 360Χ850X76LIT
    BOTTLES ICOM CYLINDERS JTG 360Χ950Χ86LIT
    [​IMG] [​IMG] BOTTLES ICOM SPARE RELEASE JTG 600X220X50LIT
    BOTTLES ICOM SPARE RELEASE JTG 630X220X56LIT
    BOTTLES ICOM SPARE RELEASE JTG 680X200 59 LIT
    BOTTLES ICOM SPARE RELEASE JTG 650X220X60LIT
    BOTTLES ICOM SPARE RELEASE JTG 680X220X66LIT
    BOTTLES ICOM SPARE RELEASE JTG 630X270X67LIT
    BOTTLES ICOM SPARE RELEASE JTG 680X240X73LIT
    BOTTLES ICOM SPARE RELEASE JTG 720X270X95LIT
    [​IMG] [​IMG][​IMG]
    YOUR ALTERNATIVE
    CLEAN FUEL......
    The JTG common rail Icom....
    .... simple
    .... programmed maintenance to along
    .... simple and not invasive term electronic.
  2. socratesthecabdriver
    283
    30
    greece
    what do the experts here at the prius chat think of this?????????
    any feed back on if its a ok idea or not!!!!!!!!!!!!!!
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,723
    2,117
    45
    North Yorkshire, UK
    I'd be interested to see your experiences. Will you go for the smaller donut tank in the spare wheel well?
    One thing I did notice is that the conversion management system was for Euro 4 whereas the Prius is Euro 5. I assume that won't cause any confusions with the emissions systems?
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,521
    Southwest Colorado
    Hard to imagine OEM warranty after conversion.
    Any data on fuel economy ?
  5. socratesthecabdriver
    283
    30
    greece
    MY MISTAKE SORRY THEY HAVE some sort of a EURO 5 ,the installer is getting information from the manufacturer of the system and then he is going to fill me in on the details ... I ALREADY HAVE A SMALL SPARE I DIDN'T OPT FOR THE FULL SIZE ...
    5th GENERATION SYSTEMS FSI
    Drive for a cleaner future JTG
    New product only from the ICOM SPA, engines for AUDI-VW-SKODA-PORSCHE, FSI, TFSI and MITSUBISHI-MAZDA GDI
    Direct injection system ICOM JTG HP.
    For new cars with direct injection technology:
    √ Even cheaper and stronger with the ICOM JTG HP
    √ Without extra gas Beck (uses gasoline)
    √ Even Easier installation
    √ Even Fewer accessories..
    [​IMG][​IMG][​IMG] [​IMG][​IMG][​IMG]
    LPG GAS alternative clean fuels you ...
    With exclusive and innovative system of high pressure to drive the engine of direct injection gasoline you like FSI, TFSI GDI or with full reimbursement from the first boot only with gas (LPG). The direct-injection system uses when you start the original installation of high pressure on the supply of petrol, so that it is already starting the process of self-spraying gas. The installation uses this function for the serial high-pressure pump and fuel injector orifices to be able to import gas directly into the ignition chamber. Only if the gas consumed completely or when using manual change is the power of the engine with gasoline. The installation is relatively easy, and have a very limited additional accessories for icom JTG HP-system. This way there is a harmonious integration of the system icom JTG gasoline. Starting on the first conversions in September 2009 for private cars.
  6. socratesthecabdriver
    283
    30
    greece
    TOYOTA MIGHT COVER PARTS OF THE ENGINE THAT ARE NOT CONNECTED TO THE TOP PART OF THE ENGINE ... PARTS LIKE PISTONS AND CAMS DON'T GET COVERED BECAUSE THEY HAVE DIRECT CONTACT WITH THE LPG FUEL .. italy has 1000000 cars that have the conversion made !!! England 40000 australia 500000 the car makers sort of accept it because of the demand ... fuel economy is the same if anything regular gas gets better mileage by a small margin ... the point of LPG fuel is that the emission are drastically better and the price of a liter of lpg versus regular is huge!!!! 1.50euro as opposed to .60 cent
  7. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    What is the cost for this dual fuel system? Looks expensive. H
  8. socratesthecabdriver
    283
    30
    greece
    install depends on cylinders anything between 1400-2000 euros expensive but if possible i definitely get that back from the gain in gas savings here in greece
  9. cit1991
    cit1991 New Member
    289
    94
    Tulsa, OK
    Liquid propane has a density of about 0.49 compared to about 0.75 for gasoline.
    So expect a drop is mileage (miles per gallon of liquid propane) of about 35% (17 - 18 MPG) relative to your gasoline mileage.
    With the price difference you state, you'll still come out ahead, but be prepared for it, and expect less range.
  10. socratesthecabdriver
    283
    30
    greece
    realy ? i knew there was a difference but not that it was so big!
