Aluminum oil filter housing with drain valve
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Oct 21, 2023.
  1. AzusaPrius
    AzusaPrius Senior Member
    1,819
    809
    Got this order in today and this should make my oil changes a lot easier.
    Having bought the aluminum skid plate that is not 100% perfect, it makes the oil drain process messier.
    This purchase will fix that issue and also give the oil filter better protection since it is not plastic and made from aluminum.
    Follow me on Instagram for more!!
    #1 AzusaPrius, Oct 21, 2023
  2. SnowMexicanuck
    Quebec, Canada
    Customer at work ran out of oil after hitting something and blew up his 2020 Corolla engine. I grabbed a free filter housing and swapped it on my '15 Prius, that's how much I hate the cartridge.
  3. Mendel Leisk
    38,634
    With horizontal-mount oil filter it won’t drain that complete through that centre spigot?
    TGrracie, Brian1954 and Grit like this.
  4. Grit
    Grit Senior Member
    6,138
    4,053
    Wilkes Land
    + 2hp though!
    Khezekiah likes this.
  5. AzusaPrius
    1,819
    809
    I know it will not drain it completely.
    It will drain enough of it that it wont make a mess like when just removing the housing.
    Then once it has drain most of it, I will remove and replace the filter.
    If the aluminum skid plate I bought was 100% flawless then I would not need this housing type but I do like that the housing is aluminum.
  6. jzchen
    jzchen Newbie!
    3,298
    1,008
    Arcadia, CA
    Crossing my fingers it is the correct tread pattern. I think @xliderider figured out the correct one but I didn’t catch onto the part number I’m afraid…
  7. AzusaPrius
    1,819
    809
    Well the seller said it would fit a Prius 2013-2014 so I assume it should fit my 2010 also.
    jzchen likes this.
  8. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    It looks like it is the right size for the Prius.
    What keeps the oil in the filter housing? I don't see any type of valve on the brass fitting. Does it come with the top that normally screws into the threaded hole where that brass fitting is attached? As shown in this picture?
    Note: oil filter housing in the picture is not the right size for the Prius, but the smaller part that screws into the top is the same.
    jzchen likes this.
  9. AzusaPrius
    1,819
    809
    Yes it is like your picture, I just attached the valve for the picture I took.
    There is an on/off on the valve, just have to unscrew it or tighten it to open and close it.
  10. AzusaPrius
    1,819
    809
    Here are some stock photos of it. Screenshot_2023-10-23-20-29-32-1.jpeg Screenshot_2023-10-23-20-29-02-1.jpeg
    TGrracie and xliderider like this.
  11. Montgomery
    Montgomery Senior Member
    2,254
    2,238
    Orange County, CA
    Interesting concept. I would rather just get the spin-on housing.
    Ryan Will likes this.
  12. Mr.Vanvandenburg
    1,027
    349
    2020 Prius Prime
    The filters come with a snap in plastic piece that drains the oil from the canister the same way, what am I missing here?
  13. Mendel Leisk
    38,634
    The aluminum underpanel mod is motivation for all this, if I'm not mistaken.
    jzchen likes this.
  14. Ryan Will
    Ryan Will Member
    63
    37
    Southern California
    I just did this on my last oil change.... and it's such an easy, cheap modification.... makes life so much easier.
  15. AzusaPrius
    1,819
    809
    I did not want to go the route of changing it and making it accept a spin on filter.
    I like to use a K&N oil filter.
    I have found the plastic version which is the same as the aluminum one here.
    But... Why would I go plastic when I can get a stronger one?
    Yes this new housing with valve opening is because I have an aluminum skid plate.
    Otherwise I would not buy it because I had no issue before the skid plate.
    Remember though, I bought a skid plate that was not 100% perfect in the oil pan area and I knew that when I bought it.
    Which is the reason I am doing this.
  16. jzchen
    jzchen Newbie!
    3,298
    1,008
    Arcadia, CA
    My Scion iQ has this metal filter housing. There is a spring loaded “Sorry game piece” fit upside down that holds the oil in. In the iQ the whole filter assembly is vertical, so unscrewing the housing leaves a “cup” full of oil. Hence there is that filter drain. What I didn’t understand during my first iQ oil change was that that little cap and gasket doesn’t keep the oil in but is a secondary seal. So I didn’t use the special tool which presses the “sorry piece” in releasing the oil. When I unscrewed the housing a mess of oil spilled out. Now I just let it be messy. The iQ does not have a panel in this area so I guess they made the housing metal for durability in case of impact from road debris.
    Your last note is what concerned me, it doesn’t fit the Prius?
  17. jzchen
    jzchen Newbie!
    3,298
    1,008
    Arcadia, CA
    @AzusaPrius Maybe this funnel will fit/help? That’s a 3/8” extension attached to the filter tool on the inside and the ratchet wrench on the other. Funnel is one of a three piece set purchased at Ross Dress for Less. IMG_1412.jpg
    If not I’d consider cutting the aluminum panel with a Dremel quite honestly.
  18. jzchen
    jzchen Newbie!
    3,298
    1,008
    Arcadia, CA
  19. Mendel Leisk
    38,634
    ^ The filter is mounted horizontal; oil will will flow down, not into that funnel.
    Assuming the aluminum shield is a pain to remove, yeah cutting an opening is best approach I think, and just stick with stock oil filter cap. Or spin-on conversion, if ambitious.
    Khezekiah and jzchen like this.
  20. Grit
    Grit Senior Member
    6,138
    4,053
    Wilkes Land
    No way!!! And do things the easy way?!
