Always in the sun
Discussion in 'Gen 3 Prius Main Forum' started by massarmor, Jun 19, 2016.
  1. massarmor
    massarmor New Member
    23
    Does anyone else lack a garage and keep their prius always parked outside in the sun?
    What do you do to preserve it?
    Also, this phone mount that sticks and suctions on the side window near the front but the sun/heat makes it fall off every time... what do you use?
    And is it worth getting the windows tinted?
    #1 massarmor, Jun 19, 2016
    49,842
    are you concerned about the paint, rubber and interior, or the battery? some people use window shades to keep the interior cooler.
    Kramah313 likes this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,585
    near Brisbane, Australia
    I've purchased a dash-mat for every car I've owned for at least 3 decades, as I've seen many of them crack from the sun. I don't have a Prius (yet), but I've had 2 cars which had steering wheels which degraded in the sun - a Mazda where the outer urethane part came adrift from the inner core, and another where the outside became sticky. Since then I've always put a cheap silver cover over the wheel when I park in the sun.
  4. marlinsmobile
    marlinsmobile Active Member
    106
    131
    Sandy Springs (Atlanta), GA
    I have to park outside in the sun about 80% of the time. I have the front and back HeatShield sun shades (purchased from the PriusChat shop). I've only had my Prius a few months, so I can't speak to the long-term impact. However, when I get into the car after work, the temp inside is comfortable, even when the outside temp is in the 90s.
    nicoj36 likes this.
  5. Xterra72
    Xterra72 Senior Member
    1,408
    1,659
    California Duster, Quick Wax and Microfiber Cloth.
    All good. No worries.
  6. booke02
    booke02 Active Member
    391
    415
    Israel
    No garage, so car always outside. Seriously hot sun in summer. I don't do anything special. Everything looking fine, both inside and out, after more than 6 years.
    nicoj36 likes this.
  7. Mendel Leisk
    39,015
    Direct sun hazes the %*!*&#%! plastic headlights I think.
  8. booke02
    391
    415
    Israel
    Ooops, forgot about that. Yes, after about 5 years I had to repolish the %*!*&#%! plastic headlights
  9. massarmor
    23
    Windshield sun shades are great and I think I'll just keep using those instead of a dash-mat.What do you use for side shielding?
    I got this phone mount that sticks and suctions on the side window near the front but the sun/heat makes it fall off every time... what do you use?
    I remember reading somewhere that toothpaste can get the haze off headlights?
    Also, I think the top layer of paint already has UV protection, so the battle is with keeping that top layer in good condition. I guess wax spray can be sufficient?
  10. Tideland Prius
    16,220
    Well I'd keep it waxed to help preserve the paint. There are products to help keep the paint from fading. I wax at least once a year (preferably twice a year if I have time).
    I would maybe invest in a car cover for times when you won't use the car during the peak solar hours of the day. It is a bit troublesome to put on and off (because it's as large as your car). The headlights will yellow if the car is parked outside every day, all year so think about a headlight restoration kit in a couple of years.
    Of course to preserve the interior, sunshades for sure. The HeatShield sunshade works quite well and is a custom fit. Someone on PriusChat linked to this site and I thought it's quite ingenious. Yes the sample photo is not a Prius (it's an MB wagon actually) but it gives you an idea of how it looks when installed
    UV Privacy Car Shades Set of 8 Toyota Prius 5dr 09 - Vanstyle
    You can download the PDF instructions to see how it's installed in the Prius.
    It comes with 8 pieces (the rear window and rear lower window are in 2 pieces each for a total of 4 pieces for those two windows).
  11. BZzap!
    BZzap! Senior Member
    1,607
    877
    A great amount of interior heat soak comes from the back light (back glass). The windshield can be blocked with a reflective curtain but what do you do for the backlight? Well, I have found that tinting is the answer to that question. I have all of my windows (not windshield) and back glass tinted. The back glass and quarter windows have very dark, high rated UV and reflective Limo tint. From front to rear, the side windows are graduated darkness to keep the law of my tail. I spent a little extra money on the best tint that was available and I can tell you that it was a very good investment.
    Just a footnote:
    Traveling through the Mojave dessert at 108 degrees the a/c set at 72 degrees I had no idea of the outside temperature until lowing the driver window to test the temperature. I didn't believe the outside temperature on the dash thermometer.
    #11 BZzap!, Jun 20, 2016
  12. booke02
    391
    415
    Israel
    You can remove the glaze with any fine abrasive. Toothpaste and a lot of elbow grease works if the glazing is not too bad, but you need to use sandpaper with an electric sander when the glazing is really bad. Once you have cleaned off the glazing, you need to coat the plastic headlamps with some sort of protective coating. There are many commercial products that include such a coating - Meguiar's is one that comes to mind.
  13. sprtent
    sprtent Member
    104
    75
    SF Bay Area
    If you have a designated parking space and if location allows, I would install a car tent/canopy.
    Mendel Leisk and bisco like this.
  14. Mendel Leisk
    39,015
    Maybe tires start cracking sooner with being parked in the sun? More of a factor if you're a low mileage owner.
  15. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    All of my cars have always lived outside. I wash & wax a few times per year. The VentureShield film seems to have prevented the headlights from hazing. I noticed that the logo on the nose has hazed but I'm not planning on doing anything about it.
    I know I shouldn't keep the Scangauge & the Garmin on the dash but that's where they live. The dash mat is melted to the car and the Roadster sticky pad is also melted.
    Wetting the suction cup will help your mount stay on the window longer but it will still pop off.
  16. Dilbertic
    Dilbertic Ozone
    16
    Silicon Valley
    We have 2 Prius's now, we have a "California" Garage so we keep one parked outside otherwise we couldn't get to anything in the garage. I bought the window shades from the Priuschat store I found a link for 32.95 cover the front and side small windows and I also bought a 30 car cover from ebay, seems ok just to take some of the sun off the car.. Now if I had an electric or plug in, I would almost build one of those solar charging covered things in my driveway...
  17. Kenny94945
    Kenny94945 Active Member
    791
    402
    Sausalito
    2016 Prius v wagon
    I have no tricks for "suction cup" devises and the heat.
    Keeping the cups and glass extremely clean does not seem to increase stick-ability.
    Best to remove the devices before they drop if parked in the sun.
    Sunshades are awesome.
    Window tinting can help, yet sunshades work better IMO.
    Tilt the seats forward so sunlight goes to the back of the seats.
    Some slightly open a window to reduce heat (vs dust ingestion or possible thief access)
    Car cover would also help, yet you risk the grit/ dirt on the car scratching the paint as the cover is install and/ or removed. Plus wind may lift and blow the cover around or off.
    Waxing can help, yet I believe UV rays can fade the paint waxed or not.
    Hence my vote... sunshades...good luck
  18. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I park outside...all the time.
    I use a sunshield.-A Must IMO.
    On the hottest days, also crack the windows when parked in the sun.
    I use plastic protectants that claim to have UV protection.
    I keep the vehicle clean and waxed, and pay above average attention to the exterior.
    And my vehicles have always IMO looked above the average, and maintained well.
    That being said?
    You can't really beat a garage for overall protection.
    You can only work to minimize the damage being out in the elements constantly does produce.
    Years of NOT having a garage, has taught me lots of little maintenance tips.
    In general it's easier to keep your vehicle clean, protected, and "maintain" than let it go, and then face yearly or bi-yearly resurrection efforts.
    I should say, that I imagine my living in the Northwest, which spends a large portion of the year with great degrees of cloud cover, probably helps in keeping my paint from fading.
    Might be a lot tougher to minimize that damage if you live in a sunshine climate.
    #18 The Electric Me, Jun 27, 2016
  19. Ernesto Chavez
    Ernesto Chavez Junior Member
    24
    Yes it is worth the average 150.00 cost. Also, buy the sunshade for the windshield. This helps keep the car cooler on sunny days and will protect the plastic dashboard. Finally, the window vent shades are a great add on and allow you to discretely leave your windows cracked open. Hope this helps..
