Am I in any sort of trouble
Discussion in 'Prius v Main Forum' started by bikeboy999, May 22, 2017.
  1. bikeboy999
    bikeboy999 Junior Member
    43
    Ottawa, Ont.
    2015 Prius v wagon
    Hi chatters,
    I left the Prius parked in garage for approx 80 days. I had a trickle charger keeping the 12v battery charged. When I went to start it, I had noticed that one of the tires was flat. So I backed it out of garage. When I did I saw a Hybrid Malfunction waring and the symbol for check engine was on. Is the car driveable to the dealer, approx 1 mile from me? Or will driving at varying speeds reset the system?
    Brian
  2. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    Once the tire is inflated, you should be able to drive it, it may charge and have no issues but the dealer can read the code it does have now.
    (The Prius does not make a good 'snowbird' car, it likes to be READY every week)
    #2 JimboPalmer, May 22, 2017
  3. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    I would fill up the tires and drive it around and see what's going on. It might reset itself, who knows!
    51,774
    it probably set off a speed sensor with the flat tire. pump it up (you should have pumped it to the max sidewall before leaving) disconnect the 12v for a minute, reconnect, and see if the warning comes back.
  5. bikeboy999
    43
    Ottawa, Ont.
    2015 Prius v wagon
    Thanks for the help. As soon as I had the tire pumped up the hybrid warning cleared. Driving to my appointment the check engine light was on. When I got back in the car that light cleared.
    Sooner Al likes this.
  6. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    That's why my wife and I take our Prius v south for the winter. We like to keep it as warm & comfy as possible...:)
    Raytheeagle likes this.
  7. ems2158
    ems2158 Active Member
    221
    162
    Bucks County, PA
    I've stored my Prius for 3 months every winter with a 12 volt maintenance charger with no ill effects. Sounds like the flat tire was the problem that resulted in the warning lights. Not sure I'd want to leave it stored for longer than 3-4 months. Anyone have experience with long term storage?
