Am I still rolling the dice on a 2012/2013 Prius v Three/Two?
Discussion in 'Prius v Main Forum' started by ThatOddMan, Mar 28, 2025.
  1. ThatOddMan
    ThatOddMan Junior Member
    64
    25
    Alhambra, CA
    Need your opinions. I sold my 2014 PiP back then. Now, I am planning on getting a Prius v (or a Camry Hybrid).
    But I am leaning more to the Prius v primarily for the cargo space utility. I street park overnight.
    Road noise in the cabin is not a problem since I used to drive a base 2005 Galant inline4 and currently borrowing my father's base Lancer inline4 for my daily car. Those two are loud inside compared to the 2014 PiP.
    2013 Prius v Two
    • Some 70k Miles
    • Pricing is only some $12400 (USD)
    • All service maintenance were done by Toyota dealers
    • Has yet to have a throttle body service
    2012 Prius v Three
    • Some 127k Miles
    • Pricing is only some $12,500 (USD)
    • All service maintenance, scheduled service maintenance, were done by Toyota dealers
    • Throttle body service
    • Transmission fluid service
    • Spark plugs replaced
    • Brake fluid service
    2017 Prius v Two
    • Some 105k miles
    • Pricing is some $4k more from 2012/2013 Prius v
    • All service maintenance were performed by the same Toyota dealer that 1st owner purchased it from.
    • Carfax does not list any throttle body, transmission fluid, brake fluid, and spark plugs services.
    My other option is a 2015 Camry Hybrid SE
    • Some 110k miles
    • Pricing is some $13,000 (USD)
    • Service maintenance were done by a Ford dealer and some independent mechanics after 60k miles
    • Carfax shows a minor damage on the front. Toyota emblem is missing on the front. On the picture, the hood does not do the same reflection of light as the rest of the panels does.
    Am I still rolling the dice on the 2012/2013 Prius v with higher probability of the popular issue of head gasket? Do I run away from the 2015 Camry Hybrid SE?
    Thank you.
  2. MAX2
    MAX2 Senior Member
    1,344
    422
    101
    Third planet from the Sun
    I chose the Prius V precisely because of the large cargo compartment.
    When traveling, you can comfortably settle in for the night along the entire length.
  3. rjparker
    rjparker Tu Humilde Sirviente
    9,293
    5,664
    Texas Hill Country
    The 2017 v with updated rings and pistons is the best v by far. The others are a lose lose.
    The Camry hybrid has a better drivetrain.
    The other v's will likely cost you a $2500 brake booster, a $2500-$6000 hg/engine, a stranding due to a still covered inverter, excessive oil burning due to low tension rings and poor crash test results. Not one of these is mitigated by Toyota dealer maintenance with 10km bulk oil changes and no ppi will id faults yet to come.
  4. Mendel Leisk
    40,236
    Depends. Are you willing/able to DIY the EGR cleaning?
  5. ThatOddMan
    64
    25
    Alhambra, CA
    Based on YT videos I watched on where the part is. Yes. It is doable. The components are not heavy so it won't sprain/strain my chest muscles.
  6. ThatOddMan
    64
    25
    Alhambra, CA
    That is similar to my intention for re-considering the Prius v. Using the middle and cargo area to take occasional power naps. I saw a 2000 Sienna XLE for some $1200 but that one needs some engine tune-up, replacing other worn out components, plus highly likely transmission being the vehicle is over 200k miles. However, that Sienna is chugs fuel compared to Prius only sipping fuel.
  7. djasonw
    djasonw Active Member
    958
    119
    Coconut Creek, FL
    Those prices seem quite high. I happen to be lucky with my 2013 Prius v 3 purchase. I bought it with 80k miles and the prior owner had oil changes done at 5k mile intervals. The service records were all recorded on Carfax by his local Toyota dealer. I've done all the maintenance routines suggested on this forum. I currently have 223k miles and it runs great. If you choose the v, make sure you do a thorough examination of the service records. Best of luck!
    iPhone ?
    Offline likes this.
  8. Offline
    Offline Active Member
    643
    235
    Lenexa, Kansas
    Those prices seem high. I wouldn't expect to get that much in a private sale for our 2012 Prius v Five which has every option including the Technology package, is at 55,000 miles, dealer over maintained with 5K or annual oil changes, additional winter wheels and tires, garaged night and day and looking like it just rolled off the showroom floor. I guess I'll find out later this year when I sell it. it's covered less than 1,000 miles/year since 2020 and its primary driver (my wife) hasn't driven it since 2023. I'll be taking it to the Toyota dealer soon for its annual oil change. We usually gift/sell our cast off vehicles to family/friends but none of them want this Prius. I think it is a marvelous vehicle in concept but it falls short on safety, ride quality, noise level and front seat comfort. But it's great for carrying my wife's wheelchair so we use it only for trips to local medical facilities. Valets seem to appreciate its small size. IMO, its two best features are its adaptive cruise control and quad LED headlights. I'm still disappointed that its Entune and Safety Connect services were discontinued.
  9. djasonw
    958
    119
    Coconut Creek, FL
    You can probably sell it for $4,000.
    iPhone ?
  10. Leadfoot J. McCoalroller
    7,764
    7,242
    Pennsylvania
    2018 Prius c
    I wouldn't consider the 2012 or 2013. Just too many expensive things are happening to those lately.
    The 2017 or the Camry will seem cheap in comparison.
  11. Air_Boss
    Air_Boss Senior Member
    4,124
    1,146
    New Yawk
    Depends on mileage (low is better) and upkeep (complete MX history and intervals are better) and your intended use case (moderate is better).
  12. rjparker
    9,293
    5,664
    Texas Hill Country
    The problem is 2012 and 2013 v's have a litany of expensive problems for the used buyer that could exceed $10k plus the safety issue that is hard to quantify if a crash sends you to the er.
    So reliability and safety are being traded for cost.
    #12 rjparker, Mar 29, 2025
  13. Air_Boss
    4,124
    1,146
    New Yawk
    Locally, there is a $10,000 split between the higher 2017 v 2/3 and the lower 2012 v 2/3, both at around 100,000 miles.
    So, locally, it’s the certainty of an initial $10,000 capital cost savings versus the cumulative probability and cost of expensive maintenance events later.
    MAX2 likes this.
