AM2 Fuse Blowing, NOT Inverter Coolant Pump, Prius Died While Driving, Won't Start
Discussion in 'Gen 2 Prius Main Forum' started by Chowly, Sep 18, 2022.
  1. Chowly
    Chowly New Member
    Denver
    Hello all!
    I had a friend borrow my 2008 (gen 2 II) Prius with 322k miles on the ODO to do some hard mountain driving up Pikes Peak. The car made it up fine, but as he was coming down the mountain the car shut off on him. Luckily he was able to coast to a safe pull-out point and had enough phone service to call me. After looking at the many forum posts here about the AM2 fuse blowing, it seemed like it had to be the inverter coolant pump going bad, especially because it was being heavily used while engine braking (B setting on the shifter) down the mountain.
    I came up the next day with him with a new inverter coolant pump, installed it and the AM2 fuse continued to blow. I unplugged the pump entirely, put a new fuse in and it still blows.
    One thing I should note, I was getting a check engine light before his trip for "P0420 Catalyst System Efficiency Below Threshold Bank 1". My BlueDriver code reader reports 4 possible causes including catalytic converter, exhaust leak, fouled front AFS, or fouled rear HO2S. I was intending to replace the cat and sensors soon as I replaced them 100k miles ago, and the car does burn a solid bit of oil (about 1L every 1500miles or so). I am wondering if fouled O2 sensors might be on the same circuit causing the Am2 fuse to continue to blow? I have not been able to find a full list of everything that is on the circuit with the AM2 fuse, but I know at least the inverter cooling pump dash and ignition are.
    Unfortunately, with the AM2 fuse blown, I get no dash power and the car will not start so I am unable to get another reading off my OBDII reader. This made for a real tough time getting the car on a tow dolly home as I could not figure out how to get the car into neutral without dash power. The headlights, dome lights, and much of the rest of the 12v system seems to be functioning still, and the 12v accessory battery still has a good charge.
    Any help or ideas on further diagnosing what could be faulting/grounding on the AM2 circuit that anyone can provide would be greatly appreciated! Thank you!
    Meg&Bear likes this.
  2. Tombukt2
    Tombukt2 Senior Member
    12,840
    2,307
    Durham NC
    Have you just unplugged the inverter pump left it unplugged replace the AM2 fuse and boot the car up and the fuse still blows? Is this correct
  3. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    462
    Leawood, KS
    I
    Yes. Sounds like that is correct.
  4. Tombukt2
    12,840
    2,307
    Durham NC
    So something in that circuit is running straight to ground or something very similar for it to be blowing like that I mean if you put a fuse in and you watch it while somebody pushes the start button and it blows the second you push the start button or the power button whatever there is something running straight to ground. Best thing I can say is you got to think what the last thing was that might have happened . Something was taken apart the dash was electrically worked on something plug got wire got squashed reassembling something.
  5. ChapmanF
    17,943
    When the going gets tough, the tough get wiring diagrams. Toyota Service Information and Where To Find It | PriusChat
    The heated oxygen sensors, it turns out, are not under the AM2 fuse. They are under the EFI fuse.
    Besides the inverter cooling pump, the fuel injectors, spark igniters, and everything under the 7.5 amp IGN fuse, come through AM2.
    Does AM2 blow as soon as you install it, or not until you make the car IG-ON?
    Does it blow if you have unplugged all four injectors, all four igniters, and the IGN fuse under the dash?
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Hook a 12 volt headlight in place of the AM2 fuse. It will go bright and not damage anything. Start disconnecting all devices on that buss one by one till the light goes out.
    Meg&Bear and mr_guy_mann like this.
  7. Chowly
    Chowly New Member
    Denver
    Thank you all so much! I have a lot of unplugging to do. I picked up a 12v test light probe to save myself some fuses. To answer many of your questions, yes, the fuse was blowing immediately upon placing into the fuse receptacle.
    Wiring diagrams are a bit above my pay grade, but I suppose there’s no time like the present to start learning how to read them!
    This information is gold: “Besides the inverter cooling pump, the fuel injectors, spark igniters, and everything under the 7.5 amp IGN fuse, come through AM2”
    I’ll give it a go unplugging each of these with the 12v test probe light plugged into the AM2 fuse socket and report back with my findings. It might be a day or three before I can tinker on it again.
  8. ChapmanF
    17,943
    That's important information, because the injectors, igniters, and stuff on the IGN fuse are all unconnected until the IG2 relay is on, which only happens when the car is IG-ON.
    So I normally would not suspect any of those circuits, if the fuse is blowing immediately.
    On the other hand, the Prius power source control ECU can behave a little surprisingly: it may remember it was IG-ON from before (even after disconnecting and reconnecting the battery!), so that can complicate an observation like this. Are there any other signs of the car being IG-ON? Any lights on the dash, will the turn signals flash, etc?
  9. Chowly
    Chowly New Member
    Denver
    There is a beeping sound coming from the dash when the driver door is open, the door ajar dash light does illuminate with an open door, and the key inside of the car symbol (the symbol between where the airbag light and key behind exclamation mark are) is flashing on about a 2 second interval — i replaced the CR2032 button cell battery in my key fob just to rule that out. The turn signals will not illuminate from turning the stock, but they will illuminate and flash when the hazards button is depressed.
  10. ChapmanF
    17,943
    The hazard button works any time, so that doesn't show anything. I think the door ajar light and security light also don't show much. Not sure what to make of the beeping.
    I think if the turn signals or wipers aren't active. the power source control ECU must not think it is IG-ON.
  11. edthefox5
    10,096
    4,833
    Clearwater, Florida
    If its blowing immediately you have a dead short to ground which makes me a little suspicious its not a device but something stupid like a wire chopped and touching ground or something 180 out of phase connected.
    Just ohm out the load side of that fuse with the fuse out will probably show zero ohms and then start disconnecting whats hanging off that AM2 buss till the zero impedance lifts.
  12. pasadena_commut
    pasadena_commut Senior Member
    2,538
    756
    Southern California
    That would only be guaranteed to not damage something if the headlight also restricted current to less than or equal to the value of the AM2 fuse. That may be the case here, since I think the AM2 is a 30A fuse, and headlights usually only draw 5A or so. But people should always check these values for the circuit in question before trying a technique like that.
  13. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,088
    Columbia, SC
    AM2 = 15 amp
  14. pasadena_commut
    2,538
    756
    Southern California
    Still safe then, assuming the 5A value for the light is roughly correct.
  15. Chowly
    Chowly New Member
    Denver
    AB12F2EA-1468-4F5C-A93B-57FEA5645AF6.jpeg Okay, thank you all for your patience. I’m trying my best to get up to speed on everything.
    I got a 12v test light, hooked it to the 12v power and probed the fuse receptacle. With the short occurring on AM2, I pulled the “relay unit B” in the wiring diagram (page 24) from the fuse box revealing three plugs connected to its back, *although it’s labeled C in my car*, and unplugged each of the three plugs connected to the relay unit. Only the middle plug (3i) seemed to be shorting out still so (3j) and (3k) should be ruled out.
    I’ve found in this wiring diagram searching for “AM2” that page 68 seems to have pertinent info on what’s down/upstream from the (3i) plug aka P6 Power Source Control ECU where the short must be occurring, but I’m still trying to decipher where each wire actually goes so I can physically unplug those things to see when the test light stops indicating a short in the circuit. 9F395A56-D1E6-4E08-8074-E725AAD103EB.jpeg F235A740-D3A5-4758-A92E-134AD4504479.jpeg
    SFO likes this.
  16. ChapmanF
    17,943
    Very good work.
    Yes, I had noticed that myself in some earlier post. Weirdly, those physical units are marked with letter B and C on the top, and the wiring diagram does show them as "Unit C" and "Unit B" respectively.
    Look for the page in the wiring diagram that shows the Unit B "inner circuit". You'll see that 3I pin 1 and pin 4 are the ones you care about: they are the terminals supplying power from the AM2 fuse. Pin 1 supplies power at all times, and pin 4 only when the IG2 relay closes.
    Pins 3I-2 and 3I-3 are just used to control when that relay closes. Pin 3 should measure as connected straight to ground, and pin 2 gets 12 volts from the power source control ECU when it wants to turn the car on.
    As far as I can see, nothing hangs off pin 1 (the always-powered one) except the inverter water pump wiring and the power source control ECU itself. (It stands to reason that ECU needs power for itself even when it isn't turning the relays for the rest of the car on.)
    So you can probably see with your meter or test light whether 3I-1 or 3I-4 shows as shorted to ground.
    Because the fuse has been blowing immediately, my first guess would be 3I-1. With a short downstream of 3I-4, you would not expect the fuse to blow until the IG2 relay is on.
    But it would be worth checking anyway. You could see the immediate blowing anyway, if IG2 is stuck on, or if it is getting 12 V supplied on 3I-2. You could check for a stuck-on relay easily enough, with an ohmmeter on the removed Unit B between the AM2 test points and 3I-4.
  17. sylvia davis
    sylvia davis Junior Member
    Wisconsin
    I FEEL BAD WHEN I HEAR PEOPLE HAD TO CALL FOR A TOW BECAUSE WE WNENT THROUGH THE SAME ON A MAJOR INTERSTATE. IF YOU JUST UNHOOK THE WHITE CABLE IN THE FRONT UNDER THE FUSE BOX , THE BATTERY IN THE BACK, AND PULL OUT THE ORANGE HYBRID FUSE, I THINK IT'S CALLED, IT LOOKS LIKE A LITTLE HANDLE. THEN WAIT 15 MINUTES AND HOOK THEM ALL BACK UP AND YOU CAN GET HOME. I DROVE 40 MILES AFTER THAT. THEN WE DROVE IT DOWN TO AUTO ZONE TO GET THE CODES FOR FREE. IT HAS BEEN DRIVING FINE SINCE, BUT SAID IT NEEDS AN ELECTRIC WATER PUMP, SO I FOUND A NEW ONE ONLINE FOR 70 BUCKS AND WE ARE REPLACING IT TODAY. BUT AGAIN, YOU CAN RESET IT AND DRIVE IT IN A GLITCH.
  18. Tombukt2
    12,840
    2,307
    Durham NC
    I don't think this reboot will stop the AM2 fuse from blowing sounds like there's a short straight to ground somewhere when something's activated.
  19. edthefox5
    10,096
    4,833
    Clearwater, Florida
    First stop screaming.
    Secondly the the hybrid battery in the back has nothing to do with this stop pulling out it's orange safety plug.
    If the pump has failed and has not yet shorted out and blown the AM 2 fuse you can still drive the car without doing anything. Its quite the crap shoot though as given today's temps you will be over heating the inverter as its coolant pump has failed. 40 miles is a long long way to drive with no inverter coolant. Don't be surprised if the inverter fails later because of this as it runs very very hot with out coolant
    I don't recommend driving this car with a failed inverter coolant pump.
    And you must use the OEM Toyota replacement pump your $70 Chinese pump is junk and it will fail again. The inverter coolant needs to be changed and properly bled too.
