AM2 fuse keeps blowing, unable to find cause
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Yaro, Mar 14, 2022.
  1. Yaro
    Yaro New Member
    Nampa Idaho
    Been at my issue all day with no luck, even with the help of you fine people and previous posts. I know someone has to have posted about this before, but I can't seem to find it. There have been many things that sounded close but didn't change what is going on, ill get into it.
    My 2005 Prius with about 270,000 miles has died mid drive. Died in this case means everything turned off, a fule consumption warning popped up on the screen. After pulling off the road and tring to restart the car I was met with an instant shut off and some flashing on the dash. I am unable to even get Prius into accessory mode.
    After a day of trouble shooting, I have learned that it isn't the inverter pump and it isn't the power source controller(PSC) ECU. I check those things cause I found threads here and other places that said those could be the culprits. I tried two used PSCs. One was from the exact Prius I own, a 05 Prius, and the other was from an 08 Prius. And as for the inverter pump it was recommended to unplug it to see if the car would start with it unplugged to diagnose the pump, fuse still pops with no power running to the pump.
    The only previous issue I had with the Prius was the dash would go out sometimes only to start working again after a random period of time.
    I know I am not looking at something that I need to, whether it be a thread or something in the car. Any help would be awesome, Thank you for reading.
  2. ChapmanF
    18,536
    One trick that helps, for pinning down an issue like that without going through a heap of spare fuses, is to plug in something like a "fuse buddy" where the fuse goes, and wire it through a 12 volt light bulb.
    That way, the short (wherever it is) doesn't keep blowing your fuses, it just lights up the bulb. Then you work your way through the wiring diagram (more info) to see everything that branches off downstream of that fuse, and disconnect one branch at a time until the light goes out. Then reconnect that branch and repeat with the specific end components on that branch. Before long, you've found the culprit.
    jerrymildred and PriusCamper like this.
  3. PriusCamper
    PriusCamper Senior Member
    13,049
    5,303
    Pacific Northwest, USA
    Nice... Gonna have to research fuse buddy more. Got any tips for best one to buy that's also the best price?
  4. ChapmanF
    18,536
    Well, you can see it comes in two flavors, one with its own built-in ammeter, one with ordinary test leads you can plug into your own DVM (or connect to a headlight, or something, if you're using it to trace a short). So the plain-leads flavor is less money, of course, and also more versatile.
    There's no rocket science to it, it's got a pair of blades the right shape to fit in a fuse socket, and two wires. :) It also has its own fuse socket on the side. so you can put in the fuse that came out of the socket, and the circuit is still protected while you're testing.
    The plastic case has squarish shoulders that prevent it from fitting in some locations in Toyota's fuseboxes. I took mine apart to see the shape of the actual metal bits inside, then cut down the corners of the plastic case to match, and put it back together with Plasti Dip for insulation there, so now it fits in more of the fusebox locations, anyway.
    PriusCamper likes this.
  5. rjparker
    rjparker Tu Humilde Sirviente
    10,494
    6,583
    Texas Hill Country
    The AM2 fuse is a difficult one since it is essentially a switched ignition power source that feeds many systems.
    If you have a hard fail, meaning a permanent short, a test light check looking for a ground or special tool like the fuse buddy gets you a test instrument. Then you have to start disconnecting wires usually at the connectors.
    Often techs might pick one circuit and work backwards.
    The real problem is the multiple circuits involved and the fact that Toyota schematics sometimes show black boxes such as the power source control ecu and assume you have been trained to know how and when the outputs are connected. Often one system is illustrated on a drawing, yet there are many other systems being fed by that fuse. For example the fuel injectors are powered by the fuse but you would not know that from this drawing.
    So you look for another drawing
    To add confusion, a fuse like this feeds different paths depending on your trim and options. Sometimes Toyota will show both circuits on the same drawing using * to differentiate.
    The online paid site has some advantages here since it will highlight the circuit better and link to explanations.
    https://techinfo.toyota.com/techInfoPortal/appmanager/t3/ti?_nfpb=true&_pageLabel=ti_home_search_docs_page
  6. rjparker
    10,494
    6,583
    Texas Hill Country
    Here is a similar issue. The root cause and solution is pretty common even though the car is not the same.
  7. Yaro
    Yaro New Member
    Nampa Idaho
    Thank you so much guys! I started doing troubleshooting day one. At the end of the second day I decided to replace the Power Source Controller ECU, the fuse still popped. So I replaced the dash, as it was going in and out sometimes, did my final test to find that the fuse was still popping and went home. At the beginning of day three I just put a fresh fuse in and the car started, without my dash working, but the car started. Why? I don't know. But the car has been working for 4 days now.
    I'll try to fix the dash going out issues this weekend where I'll try to solder on a capacitor.
    SFO likes this.
  8. Yaro
    Yaro New Member
    Nampa Idaho
    Not sure if anyone is still following along here, but the issue went away and reappeared again. One thing different is right before the AM2 fuse popped again, the car kept screaming at me to repark the car on a level area or something about the parking brake or something. If anyone is still following along, anything would help. Not sure where to start taking things apart as far as the parking brake goes.
  9. rjparker
    10,494
    6,583
    Texas Hill Country
    I doubt it has anything to do with the manual parking brake. Perhaps the Park position shift actuator was not working meaning the car could roll when off instead of being in Park. But that could just be a side effect of 12v switched power not properly operating hybrid controls or the Park mechanism itself.
    It would be interesting to know if the fuse continues to blow or will it take an intermittent short or device failure to overload it?
    The last post from March was pointing at the dash again. Was a problem found there?
    One troubleshooting fallacy is to assume something you already checked can't be the problem. The dash and inverter pump come to mind.
    There are auto electric specialists who have experience in these kinds of difficult shorts. Isolation of downstream parts is often the key strategy. Having an excellent wiring document for your vehicle year and trim is essential. Sometimes they have to de-pin connectors, insert probes through wire insulation, bypass power to certain devices through a different path, it gets tricky. Moving wiring and connectors may temporarily resolve the issue making a permanent solution difficult. Even dealers are not guaranteed solutions in cases with something intermittent. They and others may resort to wholesale part and harness changes.
    So if diy is still the plan, I would revisit the assumptions and verify if the short is continuous.
    #9 rjparker, Aug 20, 2022
  10. mr_guy_mann
    mr_guy_mann Senior Member
    4,087
    1,997
    NJ-USA
    I might wonder if the warning message is a result of the AM2 circuit voltage going low as the high draw is overloading the fuse. I would scan all ecu's for codes.
    One way to isolate a fault is to add smaller fuse in part of the circuit. In this case, you can put a fuse holder in the ground side of the inverter coolant pump with a 7.5A fuse. If the pump has a short, it will pop the small fuse, not the AM2 fuse.
    LuckyPhelps likes this.
  11. dvelozjr
    dvelozjr Junior Member
    Los Angeles
    Wanted to add to the knowledge base on how our “AM2 fuse” fix went. TLDR: swapped out inverter cooling liquid fluid pump for DIY successful repair. Part number for 2008 Prius: OE 04000-32528/G9020-47031. After the vehicle unexpectedly died on the train tracks! it was towed home. It wouldn’t start and showed the key ignition icon on the dash only. After checking the AM2 fuse we disconnected the connector on the inverter cooling water pump and tried running the car. Since it finally ran without burning out the fuse, then we figured this was indeed the problem. (Note: run the car without the pump for testing purposes only (for a very short time)). Replaced the pump and verified it was working by seeing the water move in the coolant reservoir. The car has 250k miles on it.
  12. LuckyPhelps
    LuckyPhelps New Member
    FL
    Hi all, I've done quite a bit of researching on this issue to no avail. I has the inverter pump go bad, which blew the AM2 fuse. Replaced the AM2 fuse, and the dash lit up like it should, all the buzzing and whirling going on in under the hood. I looked and it appeared low on coolant assuming some was lost during the pump change. I ran to the local auto part store 5 min away leaving the car as it was (on but not running). When I got back everything was dead exactly like it was when the AM2 fuse was blown. However, this time The fuse was not blown. I checked every fuse under the hood and under the drivers console.
    From what I've read, apparently the IG2 (?) relay could be bad. Could that have died during this swapout ordeal? Where is the IG relay located? Could it be the fuse block that holds the 4 main fuses?
    There is 12v on both sides of the AM2 fuse but nothing is coming on at all except the door ajar light on the dash. The 12v battery is 12.6v and this is my daily driver that died 2 days ago.
  13. LuckyPhelps
    FL
    I would be incredibly grateful for any suggestions as this is my daily driver and needs to be towed if it's not a hidden fuse or the IG relay. Does anybody know if the IG relay is inside the AM2 fuse holder?
  14. rjparker
    10,494
    6,583
    Texas Hill Country
    The IG2 Relay is supplied by AM2 and feeds a lot of things, making your challenge more advanced. But it is located in Unit B module of the main fuse box.
    Relays by themselves rarely blow fuses. Typically it’s a load or a wiring short to ground. It could be intermittent based on something occasionally touching ground or it could be another fuse downstream.
    Knowing all the loads is key to isolating the issue. I have included a few screenshots from the wiring diagrams - which can be difficult to follow by themselves.
    This is a case where an experienced tech with online TIS / Techstream and proper probes might be necessary.
    A quick look at some of the loads based on what I could trace on a small phone.
    #14 rjparker, Sep 28, 2024
  15. Brian1954
    Brian1954 Senior Member
    2,401
    962
    South Central PA, USA
    There was a very recent thread created similar to yours. The solution to his problem was a blown 7.5 amp fuse in the fuse box under the hood. Read this thread:https://priuschat.com/index.php?posts/3481813
    Recheck all the fuses.
    #15 Brian1954, Sep 28, 2024
  16. Mr.Vanvandenburg
    1,358
    590
    2020 Prius Prime
    How about the start button, or as it used to be called, ignition switch? I went through the am2 blown fuse nightmare once. The lesser fuses after am2 were all ok. One of the culprits is ignition switch. It can blow the am2, but it can also fail itself I think.
  17. LuckyPhelps
    FL
    How would I go about testing it? Is there a wire that commonly burns up connecting the ignition switch? I know anything is a possiblility, but the car was on and working after I replaced the inverter pump. I left for 20 min and came back to it DOA. Is there a way to bypass it to verify that as the issue?
    Can you verify the ignition relay is inside the larger block that holds the AM2 fuse? img attached
    #17 LuckyPhelps, Sep 28, 2024
  18. ChapmanF
    18,536
    There's an IG1 relay in the under-dash fuse box, and an IG2 relay in Unit B as shown. (For reasons known only to Toyota, the module clearly called Unit B in the diagrams has a big letter C on it in the actual car, and the one called C in the diagrams has a big letter B on it. The ones I've seen, anyway. Maybe in certain years the letters matched.)
    Hard for me to think of a way the Power Sw goes wrong and blows AM2. Its only connections are to the Power Source Control ECU and ground. It's effectively a little game-controller input to that ECU.
    You may want to refer to a complete wiring diagram to get ideas about what could be going on.
    Toyota Service Information and Where To Find It | PriusChat
  19. rjparker
    10,494
    6,583
    Texas Hill Country
    Check the ignition coil black for 12v
    Brian1954 likes this.
  20. LuckyPhelps
    FL
    TY. I agree and I'm extremely confident it's not the ignition switch, I'm going to evaluate using whatever methods and suggestions you prius guru suggest. Where would you begin knowing the current situation?
