Amateur MFD Repair Adventure... and advice!
Discussion in 'Gen 2 Prius Technical Discussion' started by Cyclops, Jan 31, 2018.
  1. Cyclops
    Cyclops New Member
    Des Moines
    Hello All,
    I am a brand new member and this is my first post to PriusChat. Let me introduce myself as someone who is a bit of a control freak when it comes to car repair and my experience with car repair mainly deals with late models of yester-year. Basically, if it doesn't have a hybrid system and isn't fancy, I know how to troubleshoot it.
    However, I recently purchased a used Gen. 2 Prius touring with Navigation as a college graduation gift after previously having driven an '03 Mercury Grand Marquis LS and an '88 Toyota Corolla (carburetor, California smog...so many vacuum tubes) before that.
    Now on to the MFD debacle:
    The MFD display would only register my touch on the right quarter of the screen no matter where in the other 3/4 of the screen I would touch. Otherwise the display changed when I pressed buttons and reacted with no delay at all. I thought this to be a good sign because hopefully there was an issue with the connection of the digitizer to the board and simply unplugging and re-plugging in that connection would hopefully solve the issue.
    In the mean time, I had gone to a Toyota Dealership to get the part number of the MFD and they reported back it would be 86110-47071 and I ordered one on eBay for a relatively cheap $176 compared to the dealer's quote of $9,700. The eBay MFD came and I waited until I would extract my own to see if this one would work and I could be free of the need to disassemble my own MFD.
    *The eBay MFD came slightly damaged and I was given a complete refund. It was now mine for any salvageable purpose*
    Cut to 2 weeks later, I decide to extract the whole assembly to see if the good old "Unplug and Replug" will sort things out with the touch screen It does not. Model of MFD acquired: 86110-47220. The eBay one will not work because it was purchased with an incorrectly given part number (the 86110-47071 is the incorrect part number).
    From here on out, the incorrect MFD will be called "MFD1" and the correct one will be called "MFD2"
    Anyway, with half of my dash disassembled, I continued to drive around for the next week contemplating my next move.
    I decided that I would extract the display assembly from MFD1 and put it into MFD2. This was not possible because the cables are in very different positions. I then decided that I would at least plug in MFD1 to confirm that works even though it won't fit my Prius. I plug it in and the screen remains black and the airbag (SRS) light is permanently illuminated. What. The. Hell.
    Being scared that I have royally screwed something up in my car, I plug in MFD2 to see if it still powers on. It does not! MFD2's screen is black and it is not responsive at all. This is where things get weird. Somehow in fiddling with the MFD of my car, I have managed to disable the airbag (SRS) system?!
    Just today, I brought the car down to my local mechanic and he told me there are B1650 and B1794 codes on the car. He is fixing them and I'm going to just by another working MFD for my car on eBay.
    TL;DR
    Advice: Don't plug in MFDs that aren't exactly the model of the one you pulled out of the car.
    Has anyone experienced SRS faults when replacing the MFD? Also, does anyone know if alldatadiy has comprehensive electrical diagrams for the MFD harness cables?
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Go to toyotatechinfo.com
    You can buy a 2 day subscription to the factory service manual. Get your printer ready to print like it’s never printed before.
    Also the Prius g2 electrical diagram is avail on eBay once in a while pretty cheap I got one for $25. They come and go.This is the factory book.
    The factory paper manual is expensive.
    As far as your current issues I think you may have blown a fuse with the SRS nag. I will look in my book later.
    #2 edthefox5, Jan 31, 2018
  3. edthefox5
    10,096
    4,833
    Clearwater, Florida
    #3 edthefox5, Jan 31, 2018
    JC91006 likes this.
  4. Prodigyplace
    12,555
    11,773
    Central Virginia
    Report the post and tell them what you want edited.
    edthefox5 likes this.
  5. JC91006
    16,768
    8,565
    Ray's a comedian.
    Sometimes these things are saved when you don't send them to the intended party. So next post you write, it mysterious goes on that post
  6. edthefox5
    10,096
    4,833
    Clearwater, Florida
    No I swear I didn’t write that, and my posts do not have an edit button on them anymore.
    Apology to the OP.
    Cyclops and Prodigyplace like this.
  7. edthefox5
    10,096
    4,833
    Clearwater, Florida
    So the edit button showed up and I fixed it. Jesus that was disturbing. Time to go away for a while,
    JC91006 and Prodigyplace like this.
  8. Cyclops
    Cyclops New Member
    Des Moines
    Yeah, I currently have a subscription that lasts until tomorrow with toyotatechinfo but it's like pulling teeth trying to navigate it and cull information for later use. If only I had done this 4 months ago when I still had a few thousand pages worth of printing credits at my university. I'm tempted to cough up the $50 and get an alldatadiy 5-year subscription because it seems like they have just as much info as the toyotatech. As for the wiring diagram, I'll look into getting one on eBay as you suggest.
    Also, what's the SRS "nag" you speak of?
    The repair guy came back with B1650 (Occupant Classification System Malfunction), and B1794 (Occupation Classification Battery Positive Line Malfunction). At first, my scan tool only detected the B1650 which only requires a reset of the sensor that detects someone sitting in the passenger seat. Unfortunately, I don't have a SnapOn scan tool with BCM capabilities so I missed the B1794 code. Already $230 in the hole for the diagnosis... will report with the total when I get a call later today.
  9. Cyclops
    Cyclops New Member
    Des Moines
    I love fixing traditional cars, but man, this hybrid technology will be a huge learning curve! I'll have an electrician's tool box by the time I let go of this car.
    SFO likes this.
  10. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Welcome to PriusChat!!
    If reading codes is a costly issue ($230 :cautious: is a bit steep for my pay scale, even the stealership charges less :confused: ) you might think about picking up a mini-vci cable and a copy of techstream ($20 plus a laptop or similar).
    For general day to day stuff you might find a bluetooth ODB2 adapter useful at $2 (would also need a bluetooth device, like a phone or fablet).
    Guessing this 'repair guy' still has a SnapOn habit that needs regular feeding :cool:
    #10 SFO, Feb 1, 2018
  11. davecook89t
    davecook89t Senior Member
    1,089
    825
    Washington State, Florida
    Four Touring
    @MickyMatter[/USER] was kind enough to post a link to the Gen 2 Repair Manual and Electrical Diagram in this thread How do I change Coolant Temperature Sensor? | PriusChat. If you know what you are looking for, I'm sure it will be useful.
    SFO likes this.
