Amazing the way the ambient temp. hurts mileage
Discussion in 'Gen 3 Prius Fuel Economy' started by ES44AC, Nov 10, 2012.
  1. ES44AC
    ES44AC C.A.U.S
    319
    77
    The temp here has been in the 40's +/- and on this tank no matter what I do or how I drive I can't get the indicated mpg above 49.4mpg. Tire pressures are all where I normally keep them so that's not it.
    That might sound trivial but I am puzzled by how much of the difference it makes. Yes I hive used the heater on occasion but then I turn it off once it's warm in the cabin.
    I know millions would love to see 49mpg on any car but when you are used to getting 55-56, 49 is a huge change.
    ES44AC
  2. MattPersman
    MattPersman Member
    110
    33
    Indiana
    welcome to the cold weather mpg blues
  3. Zythryn
    Zythryn Senior Member
    6,406
    4,403
    Yep, really surprised me to when I first started noticing it.
    The increase in air density plays a significant role, as will increased rolling resistance.
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I've been driving a Prius since 2005 and it still amazes me when temps stay below 60F and mpg drops.
  5. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    The Prius mpg's is greatly impacted in a negative manner when the temps drop more than
    any other vehicle I have ever owned. My 2003 VW Jetta Wagon TDI (diesel) 5-speed manual
    gets 50-51 mpg in the winter and 52-54 in the summer.
    Prius gets 45-48 winter (calculated of course) and 51-54 mpg in summer....
  6. Mendel Leisk
    40,586
    I suspect if you could somehow spoof higher ambient temp (fool the car computer) your mpg would go up, but maybe with consequences, like poor heater performance, or lugging engine.
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    You would still suffer from increased rolling resistance, increased drag and longer warmup times.
  8. walter Lee
    1,126
    376
    Maryland
    As the driving temperature drops from about 70 to 40 degrees Fahrenheit, my 2010 Prius' 16 mile commute's fuel efficiency has drop from 70-75 mpg to 60-65 mpg going downhill (down 200 feet) and from 60-65 mpg to 50-55 mpg going uphill (go up 200 feet). This is despite the Prius grills are 100% blocked, the tires are over inflated to 40 psi front and 38 psi rear, and I'm using two scangaugeII s to help me with hypermiling. The reformulated 10% ethanol 87 octane gas that I'm using seems to pucker out that more quickly in the cold :rolleyes::coffee:
    F8L likes this.
  9. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I also think it has a lot to do with the winter blend of gas that's in our tanks now.
  10. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    It's not as big as you think. See Car and Driver: Mileage? No, it's Your Gallonage that Really Counts | PriusChat.
    Run some gallonage calculations yourself.
    Partly, but there are other factors. See Why mileage gets worse in winter | PriusChat.
  11. enigma88
    enigma88 Junior Member
    34
    Alberta, Canada
    It could be worse...I live in Edmonton Canada and with the cold weather (-10 degrees Celsius,14 degrees Fahrenheit) and heavy snow this week my "HybRED" got around 7.0 l/100km (33.6 mpg).:(
    mog7546 likes this.
  12. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Ouch... I thought my last tank @ 45.4 mpg was bad. Worst tank ever for me was 38.
  13. markabele
    5,084
    1,782
    Nebraska
    To the original poster:
    Are you grill blocking?
    Also, try waiting a bit with the heater until the car has had a little chance to warm up.
  14. ES44AC
    ES44AC C.A.U.S
    319
    77
    Hi markable,
    Seems like I am not alone in my complaint about the cold wx mpg.
    No I am not grille blocking at all. I have never explored the idea. W
    What do you use to block it off and will it encourage overheating?
    Reminds me of my 1965 Sunbeam Minx sedan.... yeah I know, you've never seen or heard of one. No matter... I had a piece of cardboard that I had sized and fit perfectly to cover the lower half of the rad. Soon as cold wx got here in when the cardboard and it stayed there 'til summer. Never overheated and at least I had some good heat in the car.
    It was a great little car and I lost in in a flood in the late '70's. No frills, just basic and very reliable transportation.
    ES44AC
  15. markabele
    5,084
    1,782
    Nebraska
    There is a whole sticky about grill blocking. It contains so much more information then I could ever put in this post. All I will say is... It is an absolute no brainer to do it. Costs virtually nothing and takes very little time. The thread is at the top of the fuel economy subforum.
  16. walter Lee
    1,126
    376
    Maryland
    This veteran's day holiday weekend has been very warm with the day time temperatures reaching back to 70 degrees Fahrenheit. Didn't need to wear a coat. Yesterday (November 11 2012), hypermiling on my Prius returned summertime fuel efficiency ( 70 mpg as estimated by ScangaugeII AVG meter ).
    Wacky Winter weather. Very Strange for November in the DC Area.
    ChipL likes this.
  17. PruisAz
    PruisAz Member
    140
    34
    Mesa, Az
    We finally hit the 40's for our low out west. I checked my air pressures and they were off 4-6psi. I had aired the tires just three weeks ago to 42/40.
  18. ChipL
    ChipL Active Member
    585
    85
    Reston, Va
    Yep, wild weather in our area for sure....
    Saw first hand how colder weather will affect my mpg ratings in colder weather after the nice weekend....
  19. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    None of us are immune. Cold affects all vehicles. This final winter with my previous Prius illustrates the situation well.
    My new Prius is taking a hit as well. MPG on the commute to work has dropped from the low 200's to the low 100's. Isn't that horrible?
  20. ChipL
    ChipL Active Member
    585
    85
    Reston, Va
    Did some looking at Fuelly at other cars and it seems to mirror your chart - a 15% hit... It is that at higher mpg's the differences are more pronounced..
