Amount of oil between dipstick dots?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Preeeus, Jul 11, 2018.
  1. Preeeus
    Preeeus Member
    255
    59
    On a 2010, has anyone measured the amount of engine oil to add to get from the first dipstick dot to the second one?
    And how much oil is in the engine when the dipstick is on the first (emptyish) dot?
  2. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    1.4 qts I believe. So at the bottom dot there is around 3 qts left in the engine. Check that oil! These 3rd gens are known for burning oil, especially after 150k and under heavy loads
    Preeeus likes this.
  3. AzWxGuy
    AzWxGuy Weather Guy
    982
    496
    Tucson, AZ
    2021 Prius
    Hmm, I've been working on the assumption that the full and fill dots represent 1.6 quarts. There are other threads on this, which I will now have to go research. My figure comes from an authority around these parts, Patrick Wong. I believe he stated that the dimension is the same on the Gen II and Gen III, even though the III holds more oil.
    Aaron Vitolins and Preeeus like this.
  4. CR94
    CR94 Senior Member
    2,642
    1,138
    Northwestern S.C.
    My manual specifically states 1.6 quarts or 1.5 liters. Doesn't yours?
    4.4-1.6=2.8.
  5. Mendel Leisk
    38,736
    Yeah, starting on page 426 of Owner's Manual:
    AzWxGuy and m.wynn like this.
