Amp Install and Grounding Point question
Discussion in 'Gen 3 Prius Audio and Electronics' started by Lehboy, Sep 8, 2015.
  1. Lehboy
    Lehboy Junior Member
    Hi guys I just recently installed an amp and front speaker system. I just have a minor problem because the amplifier goes into protect mode at a certain volume / level.
    I initially thought that the amp was defective (I bought it second hand), but upon emailing a shop to ask for quotes for new amps, he mentioned that I should check if the amp is properly grounded first.
    My question is what should be the ideal grounding points where I can attach the ground for the amp? The attached photo is where the ground is currently connected to.
    The amp is located near the rear battery, inside the boot storage. Amp is an Audison LRX 4.1 which just powers front speakers - Focal KRX2.
    skorpyo33 likes this.
  2. Mendel Leisk
    38,729
    That looks fine. Except, is it just my eyes, or is the cable looping through a bracket of the spare tire took kit?
  3. Lehboy
    Yeah it's just looping there - got to fix it haha
  4. mrbigh
    3,686
    699
    Long Island, NY
    whichever ground point closest to the aux 12V battery will work best
  5. Mendel Leisk
    38,729
    Where the 12 volt negative cable grounds, even? Just stack them, run the bolt through both.
  6. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Mine is under the passenger seat so can't help with a good location for yours. Just remember to keep it a very short run with correct/heavy gauge and used a bonding brush or similar to clean the bonding area of all paint, sealant or what ever.
    #6 frodoz737, Sep 8, 2015
  7. drysider
    drysider Active Member
    823
    332
    Liberty Lake WA
    Protect mode is usually caused by low voltage. You might check the 12 volt input at the higher volume range.
  8. lopgok
    lopgok Member
    177
    30
    unknown
    You might also check out the battery to chassis ground wire. No point using a really thick wire from the amp to the chassis ground when the battery to chassis ground wire is thin. I added a 6 gauge wire from the battery to chassis ground in my install.
  9. E46Prius
    E46Prius Active Member
    314
    219
    Costa Mesa
    Make sure it's as tight as possible. (not ridiculous tight) if the threads inside the receiver are painted, that wouldn't be good. Like when they dip the car for corrosion when the bolts are in place. Maybe clean up the threads with a chase or loosen/tighten the bolt a few times to rub any paint off. Take a file to any contact surface of the bolt and what it attaches to to sand off any paint.
  10. Mendel Leisk
    38,729
    Interesting. The domed pin on the end you hold in the bolt hole, to keep the brush centered?
  11. Grit
    Grit Senior Member
    6,148
    4,058
    Wilkes Land
    Check if a set of speaker wires are grounded or crossed path some where by doing a continuity test with a dmm. 9 out of 10 times the positive terminal and or positive audio cable is grounding sending amp to protection mode at louder volume. 1 of 10 be overheating amp or defected amp. Also double check if it's bridge or stereo mode and wire up accordingly
  12. frodoz737
    4,297
    2,348
    33
    Yes.
  13. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Amp shutdown is caused by current starvation, improper grounding is a very good cause of this. Do yourself a favor, run two (2) 12 Gauge stranded wires directly from the battery terminals to the cars 12v battery. This will solve this nasty problem!!
  14. frodoz737
    4,297
    2,348
    33
    Respects, but not needed if you have a good chassis ground...and a lot less wire.
  15. KK6PD
    4,003
    944
    118
    That's the problem, you almost never have a "good" chassis ground. A little time, water, you get corrosion, that equals current starvation, which is the problem here. So with the couple of bucks extra you spend for a few feet of wire, you are guaranteed not to have a future problem. All high current devices, 2 way radios, power amps, and the like, really need to go directly to the battery. It's just good install practice.
    drysider likes this.
  16. frodoz737
    4,297
    2,348
    33
    You solution works, but it's a work-around.
    Standards and Practices dictate good terminations, clean chassis ground contact and sealant as required to posts where environmental conditions dictate. Can you imagine the quantity of wire and logistics needed if all electrical systems on any vehicle required a return wire back to to the battery post? It's just not practical or done that way.
    Elektroingenieur likes this.
  17. ChapmanF
    15,643
    Not to mention that, assuming you listen to more music when the car is READY than when it is just sitting stationary in ON or ACC, the circuit path back to the battery isn't even really the one you care about, but rather the one to the DC/DC converter in the front of the car....
    -Chap
  18. skorpyo33
    skorpyo33 Junior Member
    30
    Sebastian, FL.
  19. skorpyo33
    30
    Sebastian, FL.
    Question about amp install to positive terminal battery 2010 prius. Where did you install inline power? To the bolt on top of positive terminal under red cover??
  20. ChapmanF
    15,643
    Take a close look at that red battery clamp assembly. There is a high-current fuse built into it, with an accessible bolted connection for you at the other end (over the side of the battery, where the cable from the rest of the car is attached). I think it's 120 amps. It's marked, if I remember right.
    Attaching at that point gives you some advantages:
    1. You're already protected from the max current capacity of a shorted battery. If the wiring you're adding has a lower ampacity, you still need your own properly-sized fuse, but it doesn't necessarily have to be a high-interrupting-capacity fuse, because you're already downstream of one.
    2. Most of the time (if you play music in READY mode) your power isn't coming from the battery anyway, but from the DC/DC converter at the other end of that cable. By attaching at this point, the voltage drop of the battery clamp fuse is not in your power path.
    3. There is a similar high-capacity fuse at the forward, converter end of that same cable, so by attaching at this point, you are protected by high-capacity fuses from both possible supply directions.
    This is a picture of the corresponding attachment point on a Prius Gen 1 (note the battery clamp details are a bit different). Green arrow toward lower right.
