an unsolved air conditioning (A/C, AC) issue
Discussion in 'Gen 2 Prius Main Forum' started by finandistboy, Jul 4, 2017.
  1. finandistboy
    finandistboy New Member
    New York
    I have done my best to search the forums, but haven't found an exact match for what I'm experiencing with my 2008 Prius Touring: I bought it from its second owner at 102,000 and have put an additional 18,000 miles on it thus far. If I'm cruising at highway speeds, the air conditioning system cools perfectly well. However, if I'm creeping along in stop-and-go traffic or stopped, it doesn't cool the air at all. In fact, quite often the air coming through the vents is *hotter* than the outside air, as shown in the picture. I can be flying along the interstate in perfect comfort, and within 5 minutes of exiting onto slow surface streets, the temperature of the air coming through the vents may rise 20, 30, or even 40 degrees. I have had the car looked at both by an independent shop (no "leaks") and a Toyota dealer (no "codes" or apparent equipment malfunctions) and neither of them can find anything specifically wrong. These forums have variously fingered the compressor (front end collisons with deer and inappropriate recharging by body shops, using non ND-11 oil), condenser & dryer sock, expansion valve, evaporator, and amplifier module as potential culprits for air conditioning problems, but again, I would imagine the dealer would have examined all of these components. Any ideas of what they may be missing? Works fine at speed (with steady airflow into the front of the car), but fails otherwise. Air is blowing from the vents, and the whine from the compressor is evident when standing near the hood, but something in between is awry!
  2. JC91006
    16,480
    8,397
    You should check if your inverter pump is working. If it has failed, it would explain the no ac
  3. dolj
    dolj Senior Member
    7,645
    3,858
    Wellington, New Zealand
    So are you saying this happened? Or not?
    In any case, has there been any front end work that require removing the radiator cooling fans? These rotate one, clockwise and the other counter-clockwise and if installed reversed, they try and push air through the radiator instead of sucking the air through. Only at high speed can the cars airflow counter the pushing of the air and provide enough airflow to cool the engine and a/c. Check them and if they are pushing air back through the radiator, change them over so they suck air from the front to back.
    If not that, nothing else comes to mind.
    Aegean likes this.
  4. ChapmanF
    15,563
    I would definitely follow up on dolj's suggestion about the front fans ... checking that they are rotating in the correct directions (and also that they are rotating at all). And check that you get both rotation speeds. I don't own a Gen 2, so it's possible I'm wrong about your model, but Gen 1 definitely had the two fans wired to achieve a low speed (by connecting the motors in series) and a high speed (by connecting them in parallel), and your repair manual should lay out what the conditions are that will call for each speed, so you can make sure both are tested. (I could see a shop possibly missing a problem if they see the fans working at one speed, and haven't tested the other.)
    The absence of fan-drawn airflow through the condenser is exactly what the symptoms you've described sound like. None of the other stuff suggested makes the remotest shred of sense if those are the symptoms you're having....
    -Chap
    pleasedpriusowner and WilDavis like this.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    Yes chapman that's how the g2 fans are wired also via a relay. I'm with you one of the fans probably replaced post deer hit are not working properly, when ac on an temp set to LOW. Making it max cool the fans on the rad should both be sucking air through the rad into the engine compartment.
    And both fans on full blast.
    Or front condenser in front of rad is really full of crud. Take the black plastic cover that's on top of the rad off so you can see the condenser face should look pretty clean bright aluminum, buy 2 cans of coil cleaner from Home Depot and hose them down with that cleaner.
    pleasedpriusowner likes this.
  6. finandistboy
    New York
    Thanks to all of you for your informative responses --- I plan to show these to the mechanic when I take it in and ask him to check the fans. Re: JC91006, the inverter coolant reservoir was leaking and got replaced back in April, but there was indication of a faulty inverter pump itself. The Carfax did show two deer collisions in the past (with its previous owners, in suburban NJ).
  7. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    Whomever has looked at your car, assuming you provided the information above, should NEVER EVER work on AC again... EVER!
    The FACT that the AC works normally at road speeds tells me that the fan or fans are not doing their job when you are stopped. The engine typically shuts down under these conditions, so no need for fans at idle, except for the AC!
    Get the car HOT, park it and see if you can visually inspect both fans for running with the AC on. If not, have the fan controls looked at. They are also at least two speed fans, low and high. They should be spinning, but not super fast then switch to faster after a few minutes of being parked with the AC on.
  8. ChapmanF
    15,563
    While the fans are wired in a two-speed arrangement, I'm not sure it would be obvious in isolation whether one is seeing the low speed or the high speed (unless you were watching/listening when the speed switched). That was why I suggested looking in the manual to see the actual conditions stated for when the fans run at each speed. In Gen 1, for example, any of: the ECM, the A/C amplifier, or the A/C single pressure switch, would be independently able to pull in the relay that switches the fans to high speed. But the details might be different in Gen 2.
    -Chap
  9. edthefox5
    10,096
    4,805
    Clearwater, Florida
    Again in max cool where it says LOW on the temp gauge on the mfd both RAD fans are at max speed on a G2. Pretty straight forward.
    Not neccesary to mention isolation whatever the hell that is and the ECM or the ac amplifier or the ac pressure switch and Jesus Christ the manual....
  10. ChapmanF
    15,563
    "in isolation" isn't any kind of car-specific jargon, it just means what it means in plain English. If somebody showed you some fans running at one speed, and didn't show you the other speed to compare it with, would you be able to tell which speed you were seeing?
    I'll provisionally take your word about the conditions that guarantee high speed in a Gen 2 (even though it's not clear that they would in a Gen 1), because I'm not facing an A/C problem in a Gen 2 so to me it's not worth looking up. To someone who is facing an A/C problem in a Gen 2, it might be.
    -Chap
  11. xraydog
    xraydog Junior Member
    Arizona
    OP are you noticing your fans going to High speed? You might want to check and make sure your High and Low side refrigerant pressure sensors are operating properly.
  12. dolj
    dolj Senior Member
    7,645
    3,858
    That was six years ago, not sure the OP is still waiting on advice from us.
