Analysis and Model Validation of the Toyota Prius Prime
Discussion in 'Prime Technical Discussion' started by Marine Ray, May 23, 2020.
  1. Marine Ray
    Marine Ray Senior Member
    1,139
    942
    Sparks, NV
    This Prius Prime report is WAY in the weeds and above my intelligence level. For me, one takeaway is point of view that the PP normally depletes its electric energy first, in charge-depleting mode. If it depletes the battery state of charge (SOC) to a certain point (14.5% SOC) ,the vehicle maintains the battery SOC, in charge-sustaining mode.
    Box
    LightningBolt, kevin.c and schja01 like this.
  2. Marine Ray
    1,139
    942
    Sparks, NV
    I'm aware that the PP uses EV first, just never heard it called charge depleting mode.
  3. john1701a
    john1701a Prius Guru
    12,760
    5,246
    57
    CD (charge depleting) and CS (charge sustaining) were terms commonly used back in Volt's time, prior to enthusiasts discovering it was really a PHEV not actually an EREV. Identification of those operating modes seemed clear until the label of "EV" became easier to understand, since BEV would otherwise confuse matters.
    Look at it this way, if you are plugging in at a charging-station, no should care whether there is an engine and how it may be used. The point is to promote the use of electricity for transportation, taking advantage of external sources. The term "EV" is quickly becoming a means of simply informing a plug is somehow involved.
    This is the stage we have been hoping to reach for a long time, where the audience is growing and those among them have little to no background in vehicle design. They just want it to somehow always deliver a clean & efficient drive, taking advantage of having a plug. In other words, they would never read anything titled "Analysis and Model Validation". :eek:
    Tideland Prius and Marine Ray like this.
  4. schja01
    schja01 One of very few in Chicagoland
    1,754
    1,168
    Chicagoland
    2018 Prius
    My two takeaways:
    1) Kudos to ANL for doing the Analysis and Model Validation.
    2) Kudos to the Toyota engineers for their design work on the Prius and Prius Prime’s Hybrid Synergy Drive.
    Being that I live in the Chicago area there are three places I’ve been to that I’ve walked away utterly amazed. ANL, FermiLab, and Yerkes Observatory (not technically Chicago but not a bad drive).
    #4 schja01, May 24, 2020
    Marine Ray likes this.
  5. Bill Norton
    Bill Norton Senior Member
    1,869
    614
    MONW, Ks.
    I agree, EREV was just a confusing marketing term. The Volt is almost always a 150HP EV, even when the engine is adding its part. It's slightly different that way from other PHEV's.
    I also agree that having plug-in cars at charging stations sends the right image to those that notice 'that line of cars plugged in over there..':D
    Only, I care when that Volt or Prime has been done charging since 10AM and I'm still waiting hours later for an L2 to open up so I can charge my BEV.
    Fortunately it's never a pinch with 82 miles on tap and a network of DCFC stations around town if necessary.(y)
  6. bisco
    49,694
    that was completely incomprehensible, compared to how the owners manual describes it
