Android Auto Wireless Adapter
Discussion in 'Prime Accessories and Modifications' started by epete, Jan 27, 2025.
Tags:
  1. epete
    epete Member
    76
    27
    New Jersey
  2. BiomedO1
    BiomedO1 Senior Member
    2,774
    1,473
    SacTown, Ca
    You need to double check this!!! ONLY the base model had Android Auto. The limited ONLY communicated through Apple Carplay. They do make Android to Apple translation boxes, just do a search on this forum.
    The short answer for a 2020 Limited Prime is NO... 2021 Prime LE yes. Details are a real witch.....
    Hope this helps....
    #2 BiomedO1, Jan 27, 2025
  3. Paul Gregory
    Paul Gregory Senior Member
    1,460
    381
    Alberta
    2024 Prius Prime
    XSE
    Since about 2019 or so, Bluetooth has been able to transfer data fast enough to be acceptable. An older car with only a cable to connect, was probably designed that way for a reason.
