Android bluetooth music question
Discussion in 'Gen 3 Prius Audio and Electronics' started by crazyjeys, Apr 30, 2012.
  1. crazyjeys
    crazyjeys Member
    135
    16
    Sunny Socal
    i have paired my android phone for handsfree on the car. everytime i go in the car and the bluetooth gets paired, music from my phone album automatically plays on the radio. is there a way that the phone function is the only one that automatically connects to the car and not play the music not unless i wanted it too?
  2. kyle5434
    kyle5434 Junior Member
    37
    Nebraska
    Does that happen even if you weren't listening to bluetooth audio the last time you were in the car? For example, if you were listening to a CD or FM radio when you last turned off the car, does it automatically switch the source to bluetooth audio the next time you start the car?
    I've never tried using bluetooth audio from my Android phone, but my head unit always starts up on the same source it was playing when the car was last turned off.
  3. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    I don't know what android phone you have but mine will pair but will not automatically start playing music unless I open up the media player and hit play. This is even in the BT tab.
  4. JamesCSmith
    JamesCSmith New Member
    59
    Turn the radio off or switch it to a different input. When you turn on the radio it will tell the Bluetooth device to start playing (if it was playing the last time you had it on)
    I found it annoying at first and started looking for a pause button on the radio or an option to disable the auto play until I finally realized it was exactly like a CD in any other car radio I ever owned and turning the radio on and off is the simplest was to control it. Now I like it a lot. I just hit the power button on the radio when I pull up to a drivethrou and the podcast playing over Bluetooth is paused. Later I hit power again and it resumes the podcast right where it left off. Occasionally I get in the car and I am surprised when something starts to play and I hit power to turn it of.
  5. crazyjeys
    crazyjeys Member
    135
    16
    Sunny Socal
    yes it happens even if i turn off the radio or car on am/fm or ipod. as long as it detects the bluetooth audio, it plays it automatically.
  6. crazyjeys
    crazyjeys Member
    135
    16
    Sunny Socal
    i have a HTC Amaze 4g android. it's kinda annoying that everytime i go in the car and the bluetooth syncs.
  7. seek
    seek Junior Member
    32
    Tewksbury, MA
    Go to Settings, Wireless & networks, Bluetooth settings
    Press and hold on CAR MULTIMEDIA (or whatever you called your pairing), Options
    Uncheck Media (Use for media audio)
  8. DCDave
    DCDave Junior Member
    31
    Washington DC
    I have the identical problem, which is extremely annoying. I don't want to hear the music on my phone automatically - but I do want to be able to choose to hear the music when I want to (and have the Bluetooth sync up to the other features of the phone).
    Instead, if the car's audio power button is on - even if I'm already listening to AM, FM or SAT - the screen eventually switches to BT and the phone music begins playing. [It's an old Samsung Fascinate 3G phone]
    Toyota & Samsung: is my only choice to disconnect the phone from its BT music connection so that it is unavailable for that function?
  9. crazyjeys
    crazyjeys Member
    135
    16
    Sunny Socal
    had no luck either on my tests.... any help/suggestions would be appreciated...
  10. SamelCamel
    SamelCamel New Member
    60
    Kansas
    Just FYI; I have a Sprint HTC Evo 4G and the 2012 Prius III and this does NOT happen to me. It only comes on if that was the last input I listened to.
    It may help you to know that your problem does not happen to everyone. Maybe you can delete the pairing of your phone to the car and re-create the pairing. See if it does it then.
    -Sam
  11. crazyjeys
    crazyjeys Member
    135
    16
    Sunny Socal
    that i haven't tried yet... i'll go ahead and try it. hope it works!
  12. SamelCamel
    60
    Kansas
    My other thought is, do you have any 3rd party music playing app installed on your phone?
    -Sam
  13. DCDave
    31
    Washington DC
    Just to add to previous remarks, even if I use the Prius command to disconnect the bluetooth connection to my phone for music (keeping it for phone and internet), the next time I turn on the car it will reconnect that connection automatically. Therefore, the phone will hijack the audio system (if it is powered on) and begin the music from my phone. That remains quite annoying. I can't find a setting on the phone that might affect this (it is an old 3G Samsung Fascinate). Is there anyone who has solved this problem? Can it be accessed somehow through the mobile Entune app? Anything? For what it's worth, I do not have a 3rd party music playing app and I have unpaired and then re-created the pairing -- no luck. Thanks!
  14. IraS
    IraS Member
    165
    50
    Austin, TX
    It appears to me that the problem is in the 2012 model, not the 2010. On the 2010 Prius, it appears that the music only plays if you previously selected BT on the audio screen. (That is what I see. If I have BT selected, when I turn on the car, and my cell phone is set to bluetooth enabled, the music player automatically starts playing my playlist. If I have SAT selected, the music doesn't play.)
    So, it would be most helpful if people would post suggestions only if they have a 2012 Prius and are experiencing (and preferably solved) the problem.
  15. crazyjeys
    crazyjeys Member
    135
    16
    Sunny Socal
    the unpair and pair thing didn't work... and i don't have any 3rd party music playing app either... i'm thinking it's a phone problem because when i connect my blackberry to the 6.1, it just recognizes the phone and not the music in it...
  16. ph43drus
    ph43drus Junior Member
    45
    Left of Center
    This was driving me crazy on my 2012 Prius, and once almost caused an accident (I switched to the Bluetooth audio source so I could hear Google Navigate through a complicated interchange and just as it started giving me directions, the Music app started up at loud volume, startling me).
    The good news: this motivated me to find a fix. The possibly bad news for some: the solution I found requires root access on your phone.
    Assuming you're rooted, install AutoStart Manager (free app, link goes to Google Play). Open the app, and find your Music app (I had to choose "show system apps" on the menu to get Music to show up). Tap the Music app in the list to open up its list of receivers, and uncheck (Music).MediaButtonIntentReceiver. This prevents the Music app from receiving requests from other programs to start playing (probably also prevents them from requesting pause too, but I haven't checked). It does NOT affect your ability to start or pause playing from within the Music app itself.
    Hope this helps others.
    djkenobi likes this.
  17. djkenobi
    djkenobi New Member
    Awesome. This was annoying the crap out of me. It stopped for a while, but then I updated the rom and it wouldn't stop. Even when the last thing I was listening to was my podcast app, I'd get a phone call and when I hung up music app would start. Thanks for this fix.
  18. lumpy95
    lumpy95 Member
    420
    73
    Mojave Desert, Cal.
    I have a Samsung Infuse 4G and 2013 Prius 3. Whatever source I've been listening to when I shut the radio off will start when I turn the radio back on unless I push the source button first to change the input. All seems to be working well so far on mine.
  19. Morrisdb
    Morrisdb Junior Member
    2018 Prius Prime
    I have been bugged with this problem on my 2018 Prius Prime - and tonight I think I figured it out!
    I have Amazon Music on my phone, and it was automatically connecting through BT and playing my most recent selection. I was sort of okay with it until I discovered that it was using up data.
    On the Amazon Music app home screen, I chose Settings, then under Playback chose Streaming Network Preference. I changed the preference from
    "All network connection types" to "Wi-Fi only" - Voila - no more spontaneous startup.
