Android radio problems ( help )
Discussion in 'Gen 3 Prius Audio and Electronics' started by Ron Moberts, Nov 5, 2023.
  1. Ron Moberts
    Ron Moberts New Member
    netherlands
    Upgrade
    can someone help me, I bought an Android radio for my Toyota Prius 3 2012, because my JBL/Harman 86280-0wa51 amplifier is broken, now I still have the problem that I don't get any sound on the speakers via the adapter cable, because this normally goes through the amplifier, does anyone know how I can redirect this to still get sound through the speakers, I don't know where to look anymore
  2. prius2010II
    prius2010II Member
    269
    23
    us
    Option 1 is to replace the JBL amp. Used, possibly from a junkie, may be the easiest option.
    Option 2 is to rewire the car.
  3. Montgomery
    Montgomery Senior Member
    2,254
    2,240
    Orange County, CA
    I agree with prius2010III. May be time to do a wire up seperately. It will be a lot of work, but it will solve your problem. I usually wire one speaker channel at a time from the head unit, to the amp and to the speaker and then check to see if the channel works. Kinda hard to describe without pictures and stuff. But hopefully you understand.
  4. Ron Moberts
    netherlands
    Upgrade
    ok thanks for the advice
