Android track title info in 2020 Prius Prime
Discussion in 'Prime Audio, Electronics, and Infotainment' started by Sean71, Oct 25, 2019.
Tags:
  1. Sean71
    Sean71 New Member
    Los Gatos, CA
    2020 Prius Prime
    Just wanted to post a problem I figured out in case anyone else runs into it. I have a Google Pixel running Android 10. In our 2017 Highlander the track information shows up just fine along with album art, but in our new 2020 Prius Prime, the play information was blank. Installing Entune (bleargh) didn't help at all. I wound up having to enable developer mode on the phone, and setting the AVRCP version back to 1.3. The default was 1.4, and 1.5 and 1.6 didn't work either. The track info shows up now, but not any album art. Better than nothing though.
    P.S. Also wanted to complain about the fact that there's no way to pause the music from the main home screen (or steering wheel I assume). You need to bring up the audio panel, then wait a few seconds for the "Powerd by Gracenote" logo to disappear because it is right over the tiny pause button.
    The 2020 Highlander Hybrid coming out in February is supposed to have Android Auto. Here's hoping that makes its way into the Prius as an update as well.
    illumiN8i likes this.
  2. Tideland Prius
    16,157
    Toyota changed their setting such that the parking brake has to be applied to view album art (not sure why).
    Otherwise, track info such as title, album and artist should show up.
  3. illumiN8i
    illumiN8i Active Member
    178
    139
    Grand Rapids, MI
    2018 Prius Prime
    Thanks for the tip about AVRCP 1.3! I'll try this right away on my Pixel 2 with Android 10. Track info used to show up but stopped working at some point. Must have been an android update.
    Regarding the annoying gracenote logo, you can tap it to make it disappear immediately.
    Edit: Setting AVRCP 1.3 in developer options worked! I did have to reboot my phone after making the change. Track information shows up on the car display when using bluetooth again.
    #3 illumiN8i, Nov 22, 2019
  4. bongoman
    bongoman Junior Member
    23
    2020 Prius Prime
    Technology
    Holding the Mode Button on the steering wheel usually pauses does it not?
  5. illumiN8i
    178
    139
    Grand Rapids, MI
    2018 Prius Prime
    Another great tip in this thread! Thanks, works perfectly
