angle sensor
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by moayyad, Oct 20, 2021.
  1. moayyad
    moayyad New Member
    jordan
    hello my friends how can i override the caution light for angle sensor that appeared on my dashboard
    you know that it cost too much in my country
  2. Mendel Leisk
    38,705
    Do you have the LED headlights? At least in North America, they require a tilt sensor, maybe this is what you're seeing a warning for?
    The tilt mechanism is a pair of little arms with flexible elbows, spanning from the rear axle (near mid-span) to the car body above. You can undo the bolt connection at one end of this mechanism, try flexing the arms, ensure they're not seized.
