Annoying brake sound
Discussion in 'Gen 3 Prius Main Forum' started by Zaza 13, Oct 9, 2018.
  1. Zaza 13
    Zaza 13 Junior Member
    74
    Israel
    Brake sound
  2. Zaza 13
    74
    Israel
    When I was pushing brake, the car was making annoying mecanical sound, I changed rotors and brake pads, it stoped making that sound, but braking distans with full battery steel makes my scare
  3. Zaza 13
    74
    Israel
    Changed rotors and pads, now its calm, but braking distans with full battery makes me feel ...., is it normal?
    49,444
    not if it is much further than spec, but the battery charge shouldn't affect it.
    did you use oem parts?
  5. Zaza 13
    74
    Israel
    I dont use oem, but I use quality parts. Its not problem of parts therevcould be something with bsrke system, fluid pads and etc, everything is new... battery charging efects on brakes if battery is less then 90% u can feel regenerative braking
  6. bisco
    49,444
    when you step hard on the brake (as in an emergency, or stopping distance test) it's all friction braking.
    Zaza 13 likes this.
