Annoying cigarette lighter location?
Discussion in 'Gen 4 Prius Main Forum' started by UserError, Jan 24, 2016.
  1. UserError
    UserError Junior Member
    81
    Illinois
    I noticed that the cigarette lighter is near the cup holders back by the arm rest. Have those of you that own the 2016 Prius noticed this to be a problem? I charge my phone while I drive and have it mounted to my dash for Waze.
    I like the current location of my cigarette lighter which is closer to the dash board. Is another, closer outlet?
  2. Bisque
    Bisque Member
    40
    27
    Unless you want to connect an iPod and a phone at the same time, I'd suggest using the USB port to charge your phone. Other than that, the second Power Outlet is in the back of the arm rest.
    If you have a smart phone (sounds like you're running Waze), then you also have access to your music collection via USB. Although you could also achieve that via BlueTooth.
    Additionally, 3, 3T, 4 and 4T models have a wireless charger. Just place your compatible phone (a new case may be needed) in the forward tray of the center console.
  3. UserError
    81
    Illinois
    Yea I mean I have a mount for my phone on the dash. Just seems like the cords will get in the way. I can't wait to see the car in person.
  4. BigFan
    BigFan Member
    156
    66
    New Jersey, USA
    The little bit I have used the vehicle I have used the wireless charging and Entunes (for voice dialing), hence I have not tried mounting the phone on the dash. The outlet issue is a good point if dash-mounted phone is important to you. I have to look more carefully myself to see if there is a closer power outlet than by the console. The owner's manual only shows two power outlets (one in the front console and one in the rear of the console)
  5. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    They look like poor locations for anyone who wants to use their own GPS or to leave something charging out of sight.
  6. nategold
    nategold Member
    117
    38
    Arlington, MA
    The USB port is in the same area where the 12V is.
  7. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    The traffic receiver is in the GPS power cord so the Garmin is going to be a real PITA to use. Is the front power outlet intended for the cigarette lighter? The design team needs an ergonomics lesson and has earned their Ribbon of Shame.
  8. BigFan
    BigFan Member
    156
    66
    New Jersey, USA
    I am not sure if something like this extender would work (certainly awkward).
  9. bisco
    52,383
    you could run it under the appliqué.
  10. Mendel Leisk
    41,894
    Once, many years back, I had a bad reaction to a dental anesthetic, the local, needle-in-the-gum type. Not sure what the heck happened, suspect they hit a vein or something. Anyway, after being in a strange dream place icey cold, all white, sparkely, for a bit, I came to, soaked in sweat, cold, and sick as a dog.
    The assistant happened to come back in just then (yup, shoot him up and then take off for a few minutes...), I told her I was feeling really sick and dizzy, she said "oh you need to lower your head", and started dropping the chair back further.
    I had to basically climb outa it to upchuck in the porcelain basin (old school dentist chair). That act stuck in my head: that someone's doing something they think is best for you, and you just barely manage to fight your way through their misguided good intentions.
    Anyway:
    You could pull off all the white bits, spray them matt black, and while they're off look for a source of 12 volt, wire in an accessory outlet around the shifter.
  11. UserError
    81
    Illinois
  12. FARAZ KHAN
    FARAZ KHAN New Member
    LONDON
    Active
  13. Ty D
    Ty D Junior Member
    2018 Prius
