Annoying PO456 code....
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jim Caldwell, May 10, 2015.
  1. Jim Caldwell
    Jim Caldwell Member
    144
    26
    Mathis
    Its a 2009 Prius with about 75K miles on it. I have scangauge on the dash as well as mini-VCI. It is setting PO456 code time after time. I reset it, but it comes back in about 50 mils of driving. Its not the gas cap, I turn it until it clicks every time. Something is wrong with evaporative emissions system, which I wouldn't care about, except it might mask some other fault code that is more serious, as it keeps check eng. light on all the time.
  2. JimboPalmer
    12,470
    6,871
    Greenwood MS USA
    How many gas caps have you tried?
    49,734
    maybe it's the scan gauge. are you getting any lights?
  4. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Maybe OP should first check it with another fuel cap.
  5. exstudent
    exstudent Senior Member
    2,214
    901
    Torrance, CA
    Try:
    1) replacing the seal in the threaded edge of the gas cap; that is a wear item.
    2) a new gas cap, or a gas cap for a friend's Prius that isn't throwing codes.
    3) have you topped off? Maybe the fuel filler neck or other vales related to the tank/bladder are clogged or stuck in the wrong position, requiring replacement.
    EDIT:
    Bentley states, P0456 is same as DTC P0442
    P0442 - Evaporative Emission control System Leak Detected (small leak).
    Trouble areas to resolve:
    • fuel tank cap correctly installed
    • fuel tank cap is cracked or damaged
    • vaccum hose cracks are blocked, damaged, or disconnected in Figure 1 of the circuit description; reference the circuit diagram for the fuel system
    • open or short in vapor pressure sensor circuit
    • vapor pressure sensor
    • open or short in VSV circuit for EVAP
    • VSV for EVAP
    • open or short in VSV circuit for CCV
    • VSV for CCV
    • open or short in VSV circuit for pressure switching valve
    • VSV for pressure switching valve
    • fuel tank is cracked or damaged
    • charcoal canister is cracked or damaged
    • fuel tank over fill check valve is cracked or damaged
    • ECM
    Let us know what the solution was.
    #5 exstudent, May 10, 2015
    Dino33ca likes this.
  6. new.to.prius
    new.to.prius Junior Member
    florida
    Extend warranty
  7. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    +1 try a different gas cap 1st. can't assume the cap is good. or emissions stations can check your cap with their tester (if your state has emissions testing).
  8. exstudent
    2,214
    901
    Torrance, CA
    Extended warranties are typically a waste of money for most consumers. These insurance companies are in the business of making money for themselves. Their underwriters know the odds/longevity/probability of the covered components failing. A few people here/there may win the lotto and have a big ticket item covered, but the vast majority of the time, these companies make MONEY! Besides, these warranty policies have a lot of exclusions/loop-holes.
    Found the fuel/EVAP system training guide; its intense. Hopefully a known working gas cap will solve the problem.
