Annoying Proximity Sensor Warning on 2023 Prius Prime XSE
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by prius2017prime, Jan 1, 2024.
  1. prius2017prime
    prius2017prime Junior Member
    Hawaii
    2023 Prius Prime
    XSE Premium
    I have a 2023 Prius Prime XSE Premium with all the bells and whistles, Advance Park and Panoramic View. Is there a way to reduce, turn off or adjust the volume on the proximity sensor warning when parking? When I pull into my tight garage, I am about a 1 or 2 feet away from bicycles, work benches, etc and the warning sound gets louder and more annoying the closer you get to objects, from beeping to constant alarm. I can see everything on the 360 degree camera, I do not need the annoying warning sound. Is there a Toyota Safety Sense option to reduce the volume?
  2. Tideland Prius
    16,122
    Yes it's in the Owner's manual page 166-167 and Section 5 (Drive Support Systems).
    In your MID, press < or > until the Settings icon is displayed then press OK
    Go up/down until you find "Intuitive Parking Assist". Press OK
    Turn it off.
  3. KMO
    KMO Senior Member
    1,503
    383
    Finland
    2023 Prius Prime
    And there is also an actual volume option there too.
    In the dealer/scantool settings it is also possible to adjust the sensors to not start warning as early. I don't know if that adjusts the whole scale.
    You can hit a "mute" button on the screen once the noise starts, but that's only temporary.
