Annoying squeak/rattle/clunk sound with gas pedal, Ideas?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by orie, Jul 10, 2017.
  1. orie
    orie New Member
    Virginia
    Over the last few weeks, I've noticed a really annoying squeaking or rattling noise coming from what seems to be the front drivers side wheel area. I do a ton of city driving in Washington, DC where the roads are terrible and rampant with potholes and road debris so at first I thought maybe it was just normal road noise or something similar.
    I've started to be able to pinpoint more specifically when it happens and how. It happens almost exclusively at lower speeds (10-35mph) and more particularly when I either tap the accelerator very softly or release of the accelerator slowly. It almost never occurs when my foot is not on the accelerator or if I am traveling at highway speeds (50+).
    I've published two videos to show this issue, and you can also tell from the MPG reader on the dash when I disengage the accelerator as the MPGs shoot upwards. Last week I was at the dealer for an oil change and asked them to take a look. I don't think they did a very good job attempting to diagnose it because they said it was more of a knocking sound that a squeak or rattle, and wanted me to replace the front struts ($1200). I'm not certain that is the cause.
    Anyway the videos:
    First Video
    You can clearly hear it at the 2 second mark, 11 second mark, and 15 second mark. Each time is when I release off the accelerator briefly.
    Second Video
    You can hear it at the 1 second mark, 7 second mark, and 11 second mark.
    Anyone else experience this issue? Most of my research I've found is related to brake related noises which does not appear to be the case here as this never happens when I use the brakes.
    Any input would be appreciated.
    Thanks
  2. MMtec
    MMtec Junior Member
    48
    16
    Portugal
    He have right. But isn't necessary replace it all. Could be in attachment points... replace bushings may repair the issue..
  3. Priusowner2013
    Priusowner2013 New Member
    FL
    I have same noise and was told by dealer it's the electrical power steering. $900 Part plus labor total $1700 to fix. Waiting for response to my complaint from customer service. Dealer told me it would get worse to total loss.
  4. Dxta
    Dxta Senior Member
    1,941
    769
    Lagos
    It apoppwars to me to be the bushings in the fishbone. They're known for making such noise, when the bushings begin to fail.
