Annual US Gas Saved Due to Prius Choice
Discussion in 'Gen 2 Prius Main Forum' started by efusco, Oct 11, 2008.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,193
    Nixa, MO
    Ties a bit to similar thread here: http://priuschat.com/forums/prius-main-forum/48203-barrels-oil-per-year-saved-prius.html
    But I had the thought today that despite seeing many more Prii on the road than we did 4 years ago that they still represent a darn small portion of the vehicles on the street. But then I thought...."Well, I wonder how much gas that small percentage of vehicles has saved anyway?"
    I'm too lazy to go back to 2001 and calculate gas saved per year for each individual year...though that would be a very interesting graph. I thought I could use a safe 500,000 prius averaging 46mpg (the EPA number) vs the 2009 Corolla that the EPA gives about 31mpg combined. Thus, I'm assuming that all the people who purchased a Prius would have instead have purchased a Corolla if the Prius wasn't available. Clearly that's a false assumption, but for the purpose of comparison I think the Corolla is the vehicle that is usually chosen as a point of comparison. A few people may have gotten a car more FE than the Corolla, many would have gotten something less efficient. I've decided the Corolla is a reasonable and conservative choice here though if someone would like to redo the calculations with a different number I'd take no issue with it.
    500k Prii @15k miles/year @ 46MPG = 163,043,478 gallons of gas
    burned.
    500k Corolla @ 15k mi/yr @ 31MPG = 241,935, 483 gallons gas burned.
    So ~78,900,000 of gas saved in one year b/c the Prius was chosen over the Corolla. I think most of us here believe that the acual amount is likely much bigger than that.
    I think each of us can pat ourselves on the back for doing out part in reducing the fuel consumption needs of the country.
  2. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    ;)Ok Mr. Science, how many gallons equals a barrel of oil?
  3. efusco
    19,891
    1,193
    Nixa, MO
  4. efusco
    19,891
    1,193
    Nixa, MO
    Now, considering we import 9.6 million barrels of oil PER DAY, clearly we have a hell of a long way to go.
    But, I'd like to think that we can start seeing some reduction in consumption due to people choosing other vehicles that are more fuel efficient as well. But that's just a sick number.
  5. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    very nice Fusco
    this is a conservative estimate aswell..
  6. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Evan,
    Thanks for gathering some basic figures that sketch the outline of this matter.
    IIRC, the DOD is the largest user of fuels in the country, If their gasoline is
    included in a daily usage estimate, it would distort a discussion of civilian
    vehicle gasoline consumption.
    I suppose that if we were trying to get a really meaningful base figure for the
    impact of those speculated 500K Prii in daily use, we'd also want to take out
    commercial vehicle gasoline usage too.
    At any rate, thanks again for providing fodder for thinking about this.
  7. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    I agree... nice job Fusco! Can I write you in on my ballot in November?
  8. hill
    8,303
    Our experience going from a 4x4 1998 explorer to our 2004 prius, we've been saving over 417 gallons of gas per year. Our replacement of our 4x4 2002 Range Rover for the 2006 Lexus AWD 400h SUV hybrid saves us 446 gallons per year.
  9. hill
    8,303
    30 gallons sounded a little high since a barrel is only 42 gallons . Reading the whole wiki article, I believe the gallonage is 19 1/2. the rest being fuel oil, plastic, Asphalt paint ad nausium. But 30 gallons? It'd be nice
  10. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  11. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    http://www.api.org/classroom/tools/upload/oilfacts_rgb.pdf says a barrel of oil produces 19.4 gallons of gasoline, based on US refinery yields.
  12. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    Here is a simple rule of thumb: Every time you fill up at the pump, the amount you pay is equal to the amount you are saving by owning a Prius--which gets about twice the gas mileage of a conventional car.
    I paid 20 bucks, so I saved 20 bucks. It's that simple.
