Anodized Valve Stem Caps
Discussion in 'Gen 2 Prius Accessories & Modifications' started by hackIT, Jun 17, 2008.
  1. hackIT
    hackIT Oceanic Member
    98
    Central Florida
    This is more of an accessory than a modification, but I really like them. I found a set of blue anodized valve stem caps for right around $1.99 at AutoZone. I believe they have other colors too, such as red, silver and black. I purchased a set to match my Spectra Blue, and I think they look pretty slick (see pic). Anybody else found a 'mini-mod' like this that is relatively inexpensive and adds something to their Prius?
  2. tochatihu
    tochatihu Senior Member
    9,058
    3,529
    Kunming Yunnan China
    2001 Prius
    There are some caps similar to yours, that also contain an o-ring. When tight, it provides a secondary seal in case the Schrader valve leaks a little.
  3. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    At $1.99 I think you possibly have the cheapest Prius mod ever.
    I think even a sticker is more expensive, no?
    I think the same store stocks the lighted caps too.
    ZC1
  4. jalima
    jalima New Member
    I was looking at buying nice valve caps, however, while waiting for my car to be serviced I read on one package that theirs was not to be used on cars with inflation sensors. Did yours mention anything to that effect ?
  5. hackIT
    98
    Central Florida
    You know, I really didn't notice anything on the packaging to that end, but it's worth a look before buying a set for sure. Although I have had mine on for about 2 months with no noticeable issues.
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Let's see, if green caps are for nitronized tires, are blue caps for tires filled with argon?
    Tom
  7. ZC1
    711
    Metro Detroit
    Holding out on us Tom?, just tell us where you're getting the argon.
    I knew you had a tire secret....
    ZC1
  8. qbee42
    18,058
    3,074
    Northern Michigan
    I have a tank of it in my shop. I use it when I weld bronze or aluminum. I also have a tank of argon/CO2 mix for steel, and a tank of tri-mix argon/CO2/helium for stainless steel.
    Tom
