Another 12v battery problem (02 prius)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by miked983, Oct 11, 2008.
  1. miked983
    miked983 New Member
    2002 Prius
    Hello,
    I just spend around half an hour typing a post detailing my problem and all the specifics + details but then priuschat logged me out when I tried to post it and so I lost it all.
    Long story short: '02 prius, someone left a light on, won't turn on, AAA jumps it and I get error screen with third error highlighted, decided to replace with Miata batt from elearnaid, installed battery.
    Now here I'll elaborate a little, after I installed the battery, the car appeared fine with lights on and all that jazz, turned it on and seemed fine. I didn't have to go anywhere so I just turned it off after that. A few days later I tried it and it acted like it did when AAA jumped it - the error screen still shows up, the check engine light turns on (may be a new development for all I know), and the car moves SUPER slow because the gas engine cuts out after a few seconds.
    SOMETIMES (very rarely, occasionally only after many successive attempts) when I turn it on, I get no error screen/check engine but the car still moves really slowly and I don't want to take it out of the garage. This usually happens after I fiddle with the new battery. When this happens, on the engine monitor screen, the battery's charge is usually listed as very low - around 1/4th or 1/5th full. I followed the instructions very closely because I was afraid that I'd die if I didn't so I don't think the installation's the problem, although the connectors that came with the kit don't go all the way down on the battery terminals - they probably only go on about halfway down. Other than that, all connections are TIGHT.
    If anyone's had a similar problem or just has some advice please let me know. I'm a working student right now and don't have too much free time in the first place, but this new problem is now eating up all of it . Sorry if this post is a bit uninformative or anything but I lost a lot of information from my first post and I'm too frustrated to go typing it all again. Thanks in advance.
  2. tochatihu
    tochatihu Senior Member
    9,549
    3,685
    Kunming Yunnan China
    2001 Prius
    It would be very helpful if you or a technically oriented friend could measure the battery voltage when off, and again in ready mode.
    There may be something more going on here than 12v battery problems, and having a Toyota shop scan for DTCs would also be good.
