Another AC question
Discussion in 'Gen 2 Prius Main Forum' started by Bob Allen, Aug 6, 2007.
  1. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    When using AC is it better to have the recirculation funtion on? I thought that recirculating the air actually makes the AC more effective because it doesn't have to keep processing "new" incoming air, so that it takes less work maintaining the temp and humidity. Yes? No? Does the AC automatically decide to use recirc or not?
  2. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    By default, AC is set to recirculate the air. I leave it on recirculate since I subscribe to the theory that you described.
  3. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    There's an even more important reason for recirculating:
    The Most Unhealthy Commutes in America
  4. telstar
    telstar New Member
    32
    <div class='quotetop'>QUOTE(Angel Flight Pilot @ Aug 6 2007, 12:40 PM) [snapback]491351[/snapback]</div>
    I may be way off here, but back in the "old days" when in recirculate mode it meant the compressor ran continually and, of course, recirculated the cabin air not letting outside air in. If that is the case still, then running the compressor all the time will take more power than with it running off and on on the normal setting. Perhaps one of the techs could chime in as to whether the AC compressor runs all the time when on recirculate...
  5. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    If you use "auto" A/C, which is the default, BTW, my observations indicate the system uses recirc and fresh air, according to its' own desires (programming, actually).
    Use "auto" and let it do its' thing. It appears to be smarter than we. ;)
  6. Texas911
    Texas911 Member
    405
    Houston, Texas USA
    Yea, leave it on auto. It'll set the recirc on if it needs it. Usually to help cool the interior quickly then go to fresh air. Using fresh air is adviced so the condensers don't grow mold and on the very very rare chance that carbon monoxide gets trapped inside your car.
  7. KTPhil
    KTPhil Active Member
    1,379
    "I may be way off here, but back in the "old days" when in recirculate mode it meant the compressor ran continually and, of course, recirculated the cabin air not letting outside air in. "
    GM systems sort of used to work that way. They labeled the switch position "MAX COLD" and it really meant RECIRC. Older systems ran the compresser all the time and blended hot air to get the set temperature output. This wasteful practice was changed in the mid-late 70s as gas prices hit the (don't laugh) astronomical price of $1 per gallon. ;-)
  8. richard schumacher
    7,664
    1,043
    United States
    In the Prius recirc does not run the compressor continuously. Recirc at will. I recirc continuously, except sometimes if needed during defrost, to keep the cabin and my lungs cleaner.
