Another CEL Thread!!! P0138 and P2195
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by EXDXGXE4Life, Jan 31, 2011.
  1. EXDXGXE4Life
    EXDXGXE4Life Junior Member
    Wisconsin
    Another Check Engine Light Thread!!! P0138 and P2195
    First off let me say hello, and like a lot of people I stumbled upon this GREAT sight because I'm having a problem.
    My 2007 prius just rolled over 50K and about 3-4 days ago the lovely CEL came on. I was driving home from work in the lovely Wisconsin winter, and about 60 seconds from my garage the CEL popped on.
    The next day I went and filled up and made sure the gas cap was snug...CEL still on after 10+ starts.
    I'm a teacher and decided to take it in to our student's auto class. After they hooked it up to the computer the (reliable) student said I had TWO engine codes: P0138 and P2195.
    I'm guessing O2 sensor or A/F Sensor. I called my local Toyota stealer and they quoted me $360 for the O2 sensor plus $99 to diagnose and pinpoint the problem.
    I'm going to see if I can reset my CEL by unhooking the battery after I post this. *IF* it comes back on, what do you, the EXPERTS think could be the problem before I take her in and my wallet gets a little lighter???
    My gas mileage seems to have gone done a little when I accelerate, but that could also just be the 20 degree weather too. The engine does sound a little louder, but that could be my mind playing tricks. It seems to be running fine otherwise.
    Thanks in advance!!!
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,517
    38
    Santa Fe, NM
    First check all wiring. On my RAV4, the A/F sensor wires have more electrical tape on it now than the original insulation due to rodent chewage.
  3. Patrick Wong
    18,200
    6,493
    DTC P0138: Oxygen Sensor Circuit High Voltage
    DTC P2195: Air/Fuel Ratio Sensor Stuck Lean
    The basic problem is that the engine air/fuel ratio is on the lean side. I suggest that you check the engine oil filler cap and oil dipstick to ensure the cap is tight and the dipstick is fully inserted. Check the two PCV hoses to make sure that they are inserted into their fittings at the throttle body. (You probably can't see the other end of the hoses at the valve cover.) Check the connection between the air cleaner housing and the throttle body to make sure the screw clamp is tight.
    If this is all good, then raise up the front of the car on jackstands, get under the car and check the wiring to both the air/fuel and oxygen sensors to see if there is any damage.
    If you don't find any problems, then replace the air/fuel ratio sensor first and reset the DTC. Then drive the car and see if the DTC returns. If so, then replace the oxygen sensor, reset the DTC and drive the car.
    If your car still logs the same DTC after doing all of this, then you may have a fuel line pressure problem or a fuel injector problem.
    I recommend that you buy the correct Toyota air/fuel ratio sensor and oxygen sensor rather than buying aftermarket.
  4. seilerts
    3,326
    1,517
    38
    Santa Fe, NM
    Bosch is a good aftermarket option.
  5. jk450
    jk450 New Member
    55
    I disagree. Bosch can make great stuff for the OEMs, but much of their aftermarket line is decidedly down-market. And if a dealer has to sort out the problem later, they may not want to mess with the non-OEM parts. If not, their first order of business will be to toss the Bosch sensor.
  6. Patrick Wong
    18,200
    6,493
    Yes.
    Another reason I suggest buying the correct Toyota parts is that, in the event the OP is not successful in fixing the problem, when the dealer tech takes a look at the car and sees non-Toyota parts, they will be deemed suspect and the OP will have to pay undiscounted prices for the correct Toyota parts, plus the labor involved in installation.
    If the OP buys the Toyota parts on his own then he has a chance to buy from one of the Toyota dealers that offer ~25% discount from MSRP for web orders.
  7. EXDXGXE4Life
    Wisconsin
    Mr. Wong, right or wrong I will update this page. I see that you are the resident GURU here on prius chat. I can't imagine how many people you've helped and how much money you've saved people! You're the man!
  8. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    Perhaps the OP should check the air filter and clean the MAF sensor before replacing parts. It's easy enough to clean, just get the CRC MAF cleaner and follow the directions.
  9. seilerts
    3,326
    1,517
    38
    Santa Fe, NM
    Patrick and jk450, I respectfully disagree with both of you. If either of you have stories of Bosch O2 sensors being a disaster in the Prius compared to paying extra for the Toyota part, please start a new thread so as not to hijack this one. I've yet to have a problem, or hear of others who have had a problem, with Bosch O2 sensors. I'm not claiming that all Bosch aftermarket parts are good, but they did invent the O2 sensor. From experience on the Honda Insight side, a 5 wire Bosch A/F sensor, $175 from Amazon, is the replacement of choice, given that the Honda MSRP is $400.
    Edit: I started a new thread on aftermarket parts. Please continue this part of the discussion there.
  10. Patrick Wong
    18,200
    6,493
    I won't argue the question about whether the aftermarket Bosch O2 sensor is actually better or worse than the Toyota-supplied part.
    My main point is that if the OP cannot repair the problem himself and has to go back to the dealer for help, the first thing the dealer tech will do is to replace, at the OP's expense, any non-Toyota parts that are potentially relevant to the car's problem. Hence, the OP will now be paying for these parts 2x, at highly disadvantageous prices.
    The correct Toyota air/fuel ratio sensor costs $162 while the oxygen sensor costs $113 here:
    Champion ToyotaWorld
    I do not think these prices are so high, as to make it worthwhile to use aftermarket which may have the wrong wiring harness connector, etc.
  11. EXDXGXE4Life
    Wisconsin
    Alright so after an eternity I finally got it all taken care of for about $600...... The dealership first said the rear o2 sensor was bad...so they replaced it about a week later. Going to work the next day the light kicked on and boy was I ANGRY!!!! I took it in and somehow the front o2 sensor had also gone bad in that week (yeah right...). So they replaced the front o2 sensor with free labor that saved me $50. It's been about a week and the light has stayed off. Thanks everyone for your help!!!!!!!
