Another Dealer Service nightmare - stripped oil pan threads
Discussion in 'Gen 3 Prius Main Forum' started by wr69, Feb 28, 2022.
  1. wr69
    wr69 Member
    143
    79
    portland, or
    Before I tear the dealer a new @$$hole tomorrow, I thought I would run this by you good folks here on PC.
    Some background: Last summer after years of dealer service work, I realized stuff wasn't getting done, that I was mislead on maintenance intervals (such as 10k oil changes versus 5k), and I was simply fed up with stupid little things. Like for example, the tech's checklist showing tire pressure was checked and filled, but my spare was flat and the drive tires were 5psi too low. And my oil gravel guard was basically falling off, after the dealer supposedly changed oil. How can you not have a few spare pop rivets and replace them while you are under the car, doing an oil change?!?! A side store on the gravel guard: the oil maintenance "flap door" was basically cut off at some point in the past, and I didn't realize this either until the last 6 months, while doing my own work.
    Well, here we are today and I'm doing the first oil change on this car in 9 years. Its a 2010 G3 Prius, previously serviced at about 10k miles, per the updated Toyota synthetic oil TSB that came out many years ago. The dealer had "done" this for many years before I started rolling under my cars again. So maybe about 14 oil changes in its lifetime. It's got about 140k miles on it.
    Anyway, the oil drain plug came out weird. For those of you who have been around a while and dealt with a stripped thread, it's a familiar feeling: you unscrew the thing, and it doesn't get progressively weaker and looser as you untighten; and during the cranking off, sometimes it gets more difficult to turn for a few degrees until the little metal shreds move around. In general, it doesn't feel like a normal screw turn. Well, that was my oil drain plug. After draining, I inspected the threads and they seemed okay, but notice in the pics, the sharp edge is off the peaks of the teeth. The crush washer was bent to hell around the inside lip - probably at least 1mm inside flange above the smooth surface. But my old eyes are not so good, and it has this rubber coating, so I gave the dealer the benefit of doubt: maybe it was the rubber coating flaking off?
    Well, that was all fine and good until I went to screw and torque the plug back in at 27lb-ft. the plug wouldn't tighten. When I backed it out, I noticed the round metal shavings coming out with the bolt this time. See the pictures. Obviously, some idiot in the past had over-torqued this, forgot to install a new crush washer for years, or the oil pan is failing with age, or some combination of the above.
    Anyway, a few questions for all of you out there:
    1. the crush washer should be replaced every time you change oil. they are cheap. has anyone seen one looking as bad as mine after one duty cycle?
    2. Has anyone had a stripped oil pan after normal 10x10k oil changes, with proper torquing?
    3. Anyone have a spare drain plug around to compare the teeth thread sharpness?
    4. A little back story on the oil filter cap: While not broken, when yanking this part off today, i essentially had to kick my 1' long breaker bar to start the thing unscrewing. I estimate it took easily 50-70lb-ft to start this cap
    unscrewing. I was quite shocked by this but the cap came off in one piece, wasn't too hacked up and seemed to be intact. 70lb-ft is a far cry from the 18 lb-ft required to get this thing off, so i suspect the he-man tech at the dealer did a number on both my drain plug and oil filter cap. Has anyone ever experienced a super locked up filter cap after the normal torquing of 18 lb-ft during install?
    regarding the oil filter cap, the only theory i have now is that the gravel guard "flap-door" being cut off many years ago has somehow let road grime build up on the filter cap area or weather the thing to the point where it gets super tight over time. But I don't quite buy into my own theory. It does make me wonder though how good it is to run the car with the flap missing.
    THEORY TIME: Upon look at things, i can see that the drain plug threads stop a few mm from head-shaft joint. over time, if you re-use the crush washer as many folks are prone to do, eventually the non-threaded bolt shaft will sink into the pan thread more and more. since this shaft is thicker than the threads, and apparently the bolt is the stronger metal, you will eventually start stripping the first coarse of drainpan thread over time as the crush washer sinks and the bolt goes deeper. For those of you who want to re-use your crush washer, think twice on these G3 prius. Thats my current thinking, can be debated but i suspect that might be what partly contributed to my failure today.
    Anyway, is the dealer derelict here? Did they screw up?! pun intended. Any advice, outside of driving my car through the dealer's showroom window? I'm thinking of asking them or Toyota for a tow to another Toyota dealer, and asking for a new drain pan, plug-bolt and filter cap. This is precisely why I don't want to use these screw-ups anymore! sorry had to get one more pun in there!
  2. wr69
    wr69 Member
    143
    79
    portland, or
    I just read another post suggesting the drain plug may be softer metal than the pan! If that's the case, it would be an easy fix to get a new drain-plug. I'll keep everyone updated on how this turns out. Would be good to get some opinions or facts on which metal is stronger - the pan or the plug.
  3. PriusCamper
    PriusCamper Senior Member
    13,479
    5,443
    Pacific Northwest, USA
    yeah, new drain plug seems logical, though the threads on old ones are not severe enough to account for metal chunks... If you were working a job like this full time as a legit mechanic (not at a stealership) you'd open your tap and die drawer and see how existing thread cut responds and if need be upgrade to larger thread size knowing you got another drawer next to you with 20 different sizes of oil drain plug threads and you'd be done with all of it in less than 5 minutes and you'd move on to the next car.
    Of course if you're DIYing a problem like this... It takes a little bit longer than that.
  4. PriusCamper
    13,479
    5,443
    PS: I used to do the new washer with every oil change routine and it never leaked... Then as time went by I just re-used the same washer and it still didn't link. Then somewhere along the line I couldn't find the washer and did it without any washer and it still didn't leak. The funniest part is that it's been so many years since then I totally forget about the washer until you just now mentioned it. I wonder if anyone on here can prove you need to have a new washer on your oil drain plug because I've can't even prove that you even need a washer in the first place. :)
    Foxglove likes this.
  5. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    I cannot add much input other than stealerships suck.
    I highly doubt they will take any credit for anything.
    I used to get my oil change once a year (low miles) at the stealer, every time I I had state insp.
    Until I was changing my trans fluid and noticed the oil change flap was hacked off. (very, very common)
    I spent time calling many times to the stealer and talking with service tech manager and leaving
    messages to the gen manager.
    They never owned up to it even tho I purchased the car from them, and no one ever touched my car except them. ever.
    Well needless to say they do not get to do oil changes any more.
    I do my own since then. They get to insp once a year and get turned down for any service. (thanks, no thanks)
    I keep them in the loop just in case I need them for warranty service.
    But I do have many others to choose from if needed.
    My advice is to move on, more than likely a waste of time.
    Leave them an honest review online.
    Salamander_King likes this.
  6. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    The drain gasket looks reasonable given it went 10k mi since the last oil change. Dealer overtightened drain plug. I use a torque wrench on both once in a blue moon the filter cap is overly tight. If the filter cap was damaged before you unscrewed it then they owe you one of those also, in summary:
    Drain plug, oil pan, and oil filter cap.
    I would not take it to a different dealer because they aren't the ones that owe you, but I may just buy the three items, under tray, and clips and just replace everything on my own, then as much as possible never get service there anymore.
    REVVL V+ 5G ?
  7. hill
    9,046
    Stories like this are the reason everything on cars should be requiring a torque wrench
  8. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    I do my own service on my 2015 Prius. I don't use a crush washer at all....and I don't own a torque wrench. Never had a leak. Also the filter is always tougher to get off than you would expect, maybe the heat expands things a bit, but it's not a problem, just tougher to turn than how tight I install it.
  9. Salamander_King
    Salamander_King Senior Member
    11,026
    8,983
    New England
    I can tell you with 100% certainty that the dealer or Toyota is not going to take responsibility for this. Sorry to hear the mishap, but that's what the reality is. You can try complaining, and if you are persistent enough, they may give you a discount on an already bloated repair bill.
    As for the stripped thread on the oil pan, it is fairly common on all makes of cars. I actually managed to strip the thread on the Honda using a torque wrench to tighten the drain plug. Yep, I did it, not the dealer. And I did it with a torque wrench properly set at the specified torque. The reason was, I was still very new to doing the DIY oil change, and using a torque wrench was unfamiliar to me. Not sure if it was because of a newly purchased cheap torque wrench from HF which was defective or it was due to a complete operator error on my part. I never felt or heard the "click". This resulted in overtightening the drain plug and stripping the thread off from ~1/2 of the oil pan drain plug hole at the external side.
    You can see the sliver of the stripped thread that is still attached to the drain plug (right on the photo). The proper way to fix this would be to replace the oil pan, or at the least tap a new larger drain hole and fit it with a larger diameter drain plug. There are tools for that. But either would be costly. So, I just went with a longer drain plug of the same diameter (left on the photo below). Fortunately, Honda uses a cast-aluminum oil pan and it is thick enough so that there was still about half of the thread left on the oil pan's drain hole deeper section, so this method has worked. I have changed the oil several times since this fix and no leak has occurred, saving a quite bit of money on an older car repair.
    I have read in another thread in PC that Toyota uses very thin metal (aluminum?) for the oil pan with a welded nut inside of the pan for the drain plug. Thus it is very unlikely that you have enough thread left inside of the oil pan to "catch" with a longer but the same diameter drain plug. Also, this makes it very difficult to tap a new larger hole onto the existing oil pan. There just isn't enough material to tap a new thread inside of the oil pan surrounding the drain hole. Your only option is to replace the entire oil pan (and drain plug) as you have indicated.
    #9 Salamander_King, Feb 28, 2022
  10. PriusII&C
    PriusII&C Active Member
    432
    147
    San Jose, California
    Is this true? I had always thought that the plug is made of harder materials than the pan. The reason I ask is because the oil pan is stripped on my friend's Lexus and she is considering to re-thread the oil pan by using a larger diameter plug.
    Pdaddy likes this.
  11. Salamander_King
    11,026
    8,983
    New England
    I think for the Prius, the hardness is similar because the thread on the oil pan is welded nut on the thin metal. I don't know the physics of the screw thread and how the force is transferred, but in most cases, the stripping occurs on the oil pan thread, not on the drain plug. See my previous comment on what happened on the Hounda. Also for your friend's case, I don't know for sure if the Lexus uses a different type of oil pan as used in the Prius, but if it is similar, then tapping the oil pan may not work. (Again read my previous comment.)
  12. ChapmanF
    19,063
    It's steel, but yes, it is thin sheet stamped, with a welded reinforcement just for the threads.
    The good news is the pan is small and not awfully expensive and not awfully hard to replace, and with a new pan and new plug, you should never have such a problem again, as long as it is only you doing oil changes.
    Always make sure you have started the plug straight and true before putting any wrench on it. You should be able to easily twirl it down with your fingers all the way to where the gasket touches. Then use the torque wrench.
    From what I've seen, damaged threads happen at least as often from just starting a fastener cross-threaded as from overtorquing. If it doesn't start and twirl in easily and you just say "no problem, I've got this wrench here", then poof! your threads are wrecked.
    (When replacing the pan, observe all those cautions very carefully for all the bolts that hold the pan on! Those have quite low specified torques, and they go into soft aluminum threads of the engine block, which you can mess up by looking at them crooked.)
    As bettergolf said, the oil filter cap is always harder to loosen. I tighten mine to exactly 18 ft lb by the click every time, and every time it takes more than that to loosen. It's the resistance of the rubber O ring, which I think swells over time while it sits there.
    By the same token, I bought my 2010 used, and the first time I had to get that filter cap off, it was a lot harder than that. I barely succeeded. So yeah, sometimes it does get overtorqued, too.
    #12 ChapmanF, Feb 28, 2022
    PriusII&C and Salamander_King like this.
  13. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Toyota readily gives proper torque settings to everything in their service literature. It is one reason I suspect their vehicles are so reliable. If it shows sign of damage, it's obvious who's at fault....
    REVVL V+ 5G ?
  14. PriusII&C
    432
    147
    Thanks. We tried to tap the oil pan sometime ago, but had a hard time. We thought it was probably because the space was too small under the car (on jack stands) and we could not apply enough force. We were planning to do it again. But now with what you said, it makes sense. We may just need to replace the oil pan.
  15. Salamander_King
    11,026
    8,983
    New England
    Thanks for the clarification and the photo. Yep, there is no way to tap that thread.
    As @ChapmanF kindly shared with us in his comment, the photo of the inside of the oil pan of a Prius clearly shows that there is not enough material to tap a new thread. Yeah, your best bet is to replace the entire oil pan and gasket. But, that is definitely a job beyond my DIY capability, best left for a professional. Good luck with yours.
  16. ChapmanF
    19,063
    I don't think it has a manufactured gasket, but is sealed with "form-in-place gasket" (FIPG, a tube of goop).
    I don't think it's necessarily a bad beginner/intermediate DIY project really. The pan's a simple cover held on by 10 little bolts. Once the bolts are out, it will take some prying to separate the old goop. Don't pry in a way that will mar the bottom of the engine block.
    You have to carefully scrape all the old cured goop off the block. A plastic scraper is less likely to gouge up the block. The new replacement oil pan will, of course, be clean already.
    You need to carefully dry and clean up the bottom edges of the block with some alcohol so they are not oily for your new goop (make sure oil isn't trickling down onto the clean edges from inside the engine). There will be specific instructions for applying the goop, and how much time you have to do it, and how much time you have for putting the pan on and securing the bolts, and how much time from then until you can put oil in.
    Follow all those instructions carefully, don't cross-thread or overtighten the 10 bolts, and there you go.
    About the only two things that can go wrong are: (1) you don't do the gooping perfectly, and wind up with a bit of oil leak, or (2) you mess up threads for one or more of the bolts.
    (2) would be the bigger headache. (1) just means you get another chance to practice. (But you'd be reusing the pan then, so you have to scrape the old goop off both parts.)
  17. Salamander_King
    11,026
    8,983
    New England
    The biggest obstacle for me to DIY any repair/service on a car is the lack of a safe garage and a lift. I don't particularly enjoy crawling under a car with standard jack stands on my uneven driveway. And with my aging eyes, I can't see very well unless it is very well lit and I can position my eyes perfectly distanced from the object I am trying to focus on. Tire change (already on the rims), oil/filter, and maybe transmission fluid change are just about all I will try DIY on the underside of a car. I don't mind so much working on the body parts, electrical components, or parts in the upper engine compartment, such as the battery, fuse, air filters.
  18. PriusII&C
    432
    147
    Great instruction. Thanks!
  19. Mendel Leisk
    42,383
    Dealership has NEVER done an oil change on our 2010. I'm following the 3rd gen Canadian schedule, changing the oil every 6 months (months govern), and have done about 24 oil changes I guess. Never had any problems with the drain bolt, always torqued to spec, and replaced washer.
    The plastic shield under the engine bay has been off for every oil change (but the first), and probably 10 or more times. I finally found a few fasteners with missing teeth, ordered some spares (the correct ones) through Amayama.
    Some info that might be helpful attached.
  20. hill
    9,046
    I wonder if the manual indicates that particular thread'pitch as being torqed wet or dry .... use a dry torque setting with oil all over a plug? forget about it you're stripped
