Another HID woes
Discussion in 'Gen 2 Prius Main Forum' started by jm98, Feb 2, 2018.
  1. jm98
    jm98 Member
    155
    37
    17
    Four Touring
    Not sure what's science behind this broken HID... One day it quit working after opening HID assembly found this...
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Interesting.
    First thought would be finger prints (oil) causing a hot spot and pop.
    Have also read about housing leaks before (not sure what part of Texas you are in), but has the vehicle see any excess water/rain recently?
  3. jm98
    jm98 Member
    155
    37
    17
    Four Touring
    Heavy rains were in summer but nothing heavy since. No leak inside headlight assembly. It might be oil or finger touched by accident but very hard to analyze. The bulb was good for 1 year or so.
  4. padroo
    padroo Senior Member
    2,763
    2,250
    You were lucky it wasn't the ballast. Ballast don't swim well either. After replacing a ballast I sealed the headlight lens with my hot Glue gun around the seams. It kept water out and a cheap fix. The good thing about HID's is when you get rid of them. :)
  5. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Did you purchase an OEM bulb, or was that one of the less expensive options?
    You might be interested in this LED retrofit thread for under $40 a pair.
    HID to LED conversion | PriusChat
    Pretty sure this will be the path we take as the passenger HID bulb is cutting out at times (might even be flashing), and only a matter of time before complete failure.
    Or we could gamble on a pair of knockoffs for $12 and see how long they actually last.
  6. jm98
    jm98 Member
    155
    37
    17
    Four Touring
    This was OEM from Fleebay for $28... Only lasted one year.
    I have LED kit sitting my garage for Prius but deciding if it's worth it to install.
    Note, I have 2nd set of LED fog lights (Direct Fit) from Fleebay. The one out of first pair had LED modules broken off assembly and were floating inside Fog Light module.
    I am suspecting the LED Headlight may run in to same issue and LED modules inside assembly may break off (poor quality).
  7. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    That OEM HID bulb was Phillips brand?
    Do you have a link to those defective LED fog lights?
    Wouldn't want someone (or myself) to make a bad purchase.
  8. TMR-JWAP
    TMR-JWAP Senior Member
    6,274
    5,968
    Columbia, SC
    umm. isn't the Philips 85126 bulb a D2R?
    Shouldn't a 2006 be using a D4R? ie Philips 42406?
    I do not believe the 2006 D4R ballast is compatible with the D2R model bulb, but I may be wrong...it's happened before........
    and of course, don't the older D2R's contain mercury? I'd refrain from licking what's left of the bulb....and wash my hands really well.
    speaking of mercury..I think the D4R's are the friendly version, mercury free, which is why the ballasts are different
    #8 TMR-JWAP, Feb 6, 2018
    ITBland and SFO like this.
  9. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    ITBland and TMR-JWAP like this.
  10. TMR-JWAP
    6,274
    5,968
    Columbia, SC
    Nice info with the TSB. I think we may be on the right trail. I bet the D4R ballast eventually made the bulb internals swell and imitate popcorn. OP should probably just install 42406 D4Rs in both headlights, call it a day and hope the ballasts don't have unseen/unnoticed damage that may show up later.
    On a side note, the Philips 42406 D4Rs I purchased and installed about a year ago (Home Depot online at $51 each) in my 2007 are still going strong.
    SFO likes this.
  11. jm98
    jm98 Member
    155
    37
    17
    Four Touring
    Yes Phillips D4R.. Look like incorrect one as indicated.
    2x 9006 HB4 100W LED Cree XBD Projector Fog Driving DRL Light Bulbs 4300K Yellow
    ( 322218062666 )
    SFO likes this.
